85 klt 110 checking valve clearance??
hey just wanted to know how to check valve clearance on 85 klt 110. I read that it should be 0.12 to 0.17mm. what position should they be in ?, and do you put the feeler gauge between the rocker and the cam? Thank's again steve.
remove plug next to starter cover,
rotate eng until the T on the flywheekl appears in the hole.
make sure both rockers are loose. if they are not simply totate eng 1 more revolution.
put t in hole
lut gauge undeer the adjustable screw.
set clearance.
recheck after tightening.
//ArrowChat Integreation Code
