Results 1 to 15 of 23
Thread: HELP! another 85 250R clutch play problem
    Miami,Fla.(305)
    808
    Well- I wish I had pictures-but anyway: I have a problem with no almost no actuation as if the cable was too long -but its not-I think. (M.P.#02-0127) which I bought maybe 2 yrs ago still like new-(shiny,smooth & no binding) dont appear frayed or stretched? I have to have adj. maxed out on both ends to have it work.....BUT- My clutch actuator arm starts to engage where it should- almost perpendicular I guess you could say-or lever is pointing straight in when it starts to engage...so that SEEMS like the problem is not internal? -Am I wrong? I've seen cases when the arm catches late & rotates alot before engaging-& this is not the case.... - So before I take it apart.... I put new clutch kit recently but seemed to make things worse with the stiffer/longer springs. Anyway, could it be the wrong type clutch lever assembly??? Where do I go from here?
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Blossvale NY
    4,563
    Don't be insulted by this question, but when you did the clutch kit, did you make sure the ball bearing went back in on the clutch end of the actuator shaft??
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Miami,Fla.(305)
    808
    The play was there before the clutch kit-yes -I know about the ball & it was in there. It all looked ok last time I looked but will have to check it all again & see. But like I said-the arm seems to be actuating at the right point so I'm not sure theres a problem inside? Or can there still be a internal problem. Pushing on the arm - it works fine and disengages fully.
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Blossvale NY
    4,563
    If the actuator rod, ball and button are all on good shape, I would lean toward a cable issue.
    IDK about the rest here, but in the past I have had issues with cables not being quite right. Seems as though the cable manufacturers like to try to have 1 cable work for a few different models and sometimes they don't work really well for certain models... But its funny you have a MP cable.. I always thought they were pretty spot on..
    I have had bad experiences with new clutch and throttle cables where I had to have the adjusters maxxed out one way or the other in order to get proper operation....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Miami,Fla.(305)
    808
    OK-this should help: Thats the point where it is at rest but just where it starts to engage. Seems fine?-could the problem (play) still be inside?-
    Or could it be the type of hand lever assembly? or even the handlebars length/height causing the issue? Really seems as if it would be the cable as the cause but not sure since it seems perfect?
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Hampton, Virginia, C.S.A.
    2,664
    just an idea here... what brand cable are you using? is it motion pro or oem? if its motion pro throw it away and buy an oem. even if that doesnt fix your problem replace it anyway. i have had 4 motion pro cables break on me on different bikes. i have also had issues with getting them adjusted right. i will never buy another motion pro
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Miami,Fla.(305)
    808
    It is Motion Pro--Hmm-I wonder now what the true length of the cable SHOULD be...(OEM)
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Mexico
    9,019
    http://www.3wheelerworld.com/showthr...t=wet+clutches
    LEVERS & CABLES AND HOW TO ADJUST THEM
    All cable manipulated clutches have a clutch lever, a cable and an arm, cam or a worm gear that provides a mechanical advantage to move the pressure plate against the springs. If these parts on your ride are stock then proper maintenance and adjustment should be all you need to keep them working correctly. Sometimes, especially if someone has incorrectly routed a clutch cable, the cable housing can be pinched, kinked, or otherwise hampered from smooth operation. If you have any doubts about this you need to disconnect the cable from the point closest to the engine and move the hand lever in and out. There should be no resistance whatsoever in either direction. If there is you either have very dirty cable housing, or you need a new cable. I recommend a new cable anytime there is any unknown cause of resistance or defect in the housing as the internal damage can be worse than the exterior looks. Argue that all you want, but I think anyone who’s ever had a cable fail will agree that it’s cheap insurance. Also keep in mind that if you change any component in the clutch lever/cable assembly you may also be changing the amount of movement that is transmitted to the clutch plates. i.e. a longer distance between the pivot bolt on the clutch lever and the point where the end of the cable seats in the lever will open the clutch assembly more than a shorter distance between the two would, but the force required of the rider to pull the lever will be greater. Similar changes occur if you change the length of the lever closest to the engine that the cable attaches to. If you make it longer the clutch will be easier to pull, but the amount that the clutch pack opens will be reduced. There is often a splined connector on the lever that attaches closest to the engine. For the best possible clutch action it is recommended that you position it in a place that will see it at 90 degrees to the nearest mounting point of the clutch cable housing halfway through its pull. This will provide the least amount of resistance to the user and aside from being easier to pull it will reduce the force exerted on the cable ends that could cause premature failure. You should also try to have all the cable housing adjusters in the most neutral position possible i.e. don’t thread the entire end of the engine side of the cable all the way into the holder and have only two threads of the other end in the clutch perch. This is a sure way to ruin the threads on the hand lever perch and will eliminate the possibility of making a simple adjustment on the trail. It is a lot easier to play with these little details in the shop than it is on a hot muddy engine in the middle of mosquito invested swamp
    Mexico
    9,019
    Quote Originally Posted by 3wheelrider View Post
    In theory it doesn’t matter if the cable is 10 inches or 10 feet, what matters is its relation to the housing. If a stock cable is 2” longer than the housing and an aftermarket cable is 3 inches longer than its housing you have 1” too much of cable and it will be hard to adjust that much out of the mix. Do you have the original to compare it to?
    Miami,Fla.(305)
    808
    Good point...-No- I dont have the original to compare to. Thanx for the info. So does the position of the arm mean it should be ok internally-or not?
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Oct 2012
    Finlayson, Minnesota
    1,066
    Sorry if this is useless.. i may be mis understanding what the problem is.. but the actuator arm has 0 play when pulling the clutch? As if there is absolutely NO resistance? like nothing there. Can you take the actuator arm out and put into different spot? On my yz 125 i had to put the actuator arm in like 180 degrees the opposite way and turn it till it stopped from resistance.. then put the cable on and it was good.
    So with the cable attached now can you move the actuator arm the way the cable pulls? If so the arm is in wrong position. There should be resistance that should take a lot of force to move it.
    If this info is wrong sorry.. im just going off what my dirtbike was assuming the clutches are the same concept.
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Miami,Fla.(305)
    808
    My problem is TOO MUCH play in the cable. Clutch/Arm works fine. Just dont make sense. Im gonna have to assume its the cable like 3wheelinfeelin said. --I thought I'd have more of you would have a straight answer to this based on the actuator arm-guess not.
    Ok- How bout this: Can someone give me the measurement a OEM clutch cable should retract in & out?- Maybe that will answer my problem.-Thanx
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Kryten's Avatar
    Kryten is offline At The Back Of The Pack Arm chair racerFirst time rider
    St. Louis, MO
    157
    I have the exact same issue, initially thought it was something internal, but now it makes me wonder if it is the Motion Pro replacement cable.
    1984 ATC200S
    1984 ATC200X
    1984 ATC200M
    1985 ATC200X
    1985 ATC350X
    1985 ATC250R
    1986 ATC200X
    1987 ATC250SX
    TPC450
    2,664
    Quote Originally Posted by Kryten View Post
    yeah guys im not trying to say its for sure the problem. but i have sworn i will never use another motion pro cable. id say go oem guys thats what i did
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Miami,Fla.(305)
    808
    Measured the cable (disconnected at the lower holder) & it seems 1/2"-5/8" too long. Also, I believe my clutch (hand) lever may be compounding the issue cause it only pulls the cable 5/8" when I pull in the hand lever.-dont seem to be enough??? The hand lever has quite a inward bend that bumps the bars . I believe it was for a 450r? I guess it doesnt work well with the R?? Also -the clutch springs which were replaced are longer/stiffer which is too hard! Big strain on parts & my hand too. Damn, I wish I still had the stock clutch springs/cable/perch/lever!!!! Anyway- It may be a series of things goin on here.......
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
