How would a guy go about getting shipping rates for my atc 70? I've had several guys inquiring and I don't have the slightest clue on how or who to obtain a rate for them.
'86 ATC 250R, Build Thread http://www.3wheelerworld.com/showthr...highlight=250r
'86 "Factory Tri racing" Tri-Z http://www.3wheelerworld.com/showthr...b-Top-Tank-ect
Pile of Tecate Parts
My Feedback Thread: http://www.3wheelerworld.com/showthr...edback-for-bkm
You can call FedEx Freight or any other freight carrier and get a quote. What they will need is length, width, height, weight, and destination. Without a freight account, freight rates will not be cheap also factor in no truck dock at either pickup or destination however if you palletize the trike and take it to a freight hub and have it delivered and held at a freight hub will be cheaper. I have shipped everything from tiny boxes to large industrial machines all over the world. Your best bet as average Joe shipper with no freight account, call FedEx freight and talk with them. If you know anybody who works somewhere with a truck dock and a freight account you can use would be the cheapest way to go. There is a place called U Ship. I have used this a couple of times. http://www.uship.com/
My stepfather works for fedex freight, I don't know why I didn't think of that. I'll check with him and see what kind of deal he can get me. Thanks
just a bit of advice if you make an inquiry with u ship. Do NOT give them a phone number. I did once and my phone rang off the hook for a solid 2 weeks. Literally 8-10 calls a day for 2 weeks and 1-2 calls for the following week or so.
bkm-
I actually do have a shipping account with a few freight carriers and have looked at some rates. I didn't have an exact weight but I figured around 350 lbs. and my cost was just under $200 using Con-Way. I will look into Fed Ex and see. Good thing about my location is I do have a shipping dock. Let me know what you find out from Fed Ex and maybe it will work out. Do you think it would fit on a standard 4' x 4' pallet? If so it shouldn't be too bad as it should qualify for a pallet rate. Let me know about the dimensions and weight and I will get a firm quote. Thanks for looking into this for me.
Currently Owned
1986 Yamaha Tri-Z 350???
1985 Honda ATC 70
1985 Honda ATC 250R
2006 Suzuki LTR450
2005 Suzuki LTZ400
2005 Polaris Predator 50
2004 Polaris Predator 90
2-Honda Trail 90's (need to be brought back)
Feedback Thread http://www.3wheelerworld.com/showthr...-for-New2Tri-Z
I have found that U-SHIP is the cheapest because you can name your own price. Find out what everyone else will do it for then cut that down to what you want and post it on U-SHIP.
It was going to cost me about $700 in gas to drive over to ILL. and haul a VW Bus back to PA.,I posted a price I would pay of $500. With in 3 hours I had 2 guys that said they would do it.
I also had a Kawasaki 700 shipped from Las Vegas to PA. for $500.
http://www.uship.com/?/
I don't know how accurate placing a bathroom scale under each tire is, but I came up with 190lbs. it should fit just fine on a pallet.
In 2004 I bought an 1985 ATC 250r from New York and had it shipped to Phoenix Az for $600.
The company I used was named forward air and they provided the sealed container but had to be strapped in container
I had a 70 shipped from North Carolina to North Dakota for 300 off of u Ship some quotes are good some are ridiculous.
The stock weight of a 70 is about 170lbs. An average 4x4 pallet weight is about 40lbs. Add 10lbs for dunnage, strapping, padding etc so that puts you at an estimated shipping weight of 220lbs MOL. If the wheels are removed and stowed on the pallet, it should fit nicely within the perimeter of a 4x4 pallet. The trike will need to have all fuel removed but the engine oil is ok. I shipped two 70s several years ago and I got both of them to fit on a 4x4 plastic pallet but both trikes were partially disassembled and everything removed was packed and stowed on the pallet. The guy buying them used Uship and I got a call from the transporter at 2am saying they were in town and wanted to pick up the pallet. Turned out to be a couple of guys with a horse trailer. They moved the pallet ok but I was a bit Leary but in the end it turned out ok. For a commercial transporter, the trike will need to be palletized so it can be loaded and unloaded with a forklift or pallet cart. Most commercial transporters will pickup a pallet and that pallet will be unloaded and loaded on another trailers perhaps two or three times as it makes its way to its destination. With FedEx Freight, you can bet a pallet going from St Louis to Redding CA, that pallet will be moved from one FedEx trailer to another at least three times so the better packed and secured the trike is, the better it will travel. If you ship it on New2tri-Z's using Conway, You will probably need to take the trike ready to travel to a Conway terminal but I'm sure Conway has a terminal somewhere in or around St Louis.
With our fedex rates at work that pallet would cost us about 200 to a commercial 300 to residential ... I just shipped a 270lb pallet from texas to idaho for $150 ..
85 Honda 250sx- STILL IN PIECES!!!
84 Honda 185s - traded off
85 Yamaha 225dr - parts machine for now
83 Yamaha tri-zinger 60cc - my sons first 3wheeler. $300 for zinger, $4000 for a broken leg, memories for a life time - PRICELESS
85 Honda Big Red 250es - traded off
86 Honda 250r - traded off
85 Kawasaki Tecate - new toy
84 Honda 200m - super clean puttin around toy
I use uship exclusively. I have had incredibly good luck by trying to be smart. Which you would have the"feel" to Brian. However. I just bought a 200X off Mrclean and it is stolen. The shipper loaded it up and disappeared. I have ALWAYS,every time. Had my seller video the shipper/license/individuals etc as they leave. But I didn't this time. Police report is filed and I'm relying on Mrscleans memory now!!! But overall,I have had incredibly good luck getting bikes moved as is,drive on drive off. No crating. You can post the auction for free with no obligation. Doesn't cost a thing. Like Mickey said, I list my own price. But that's up to you.
I also have recently used u-ship. It was great and I still have his name and number. As soon as you post you will usually get somebody that will bid a very expensive amount right off. Its very easy to decline the offer. My last experience started at $755 I think and within 2 days the bids were as low as $300. I payed the $300 plus gave the shipper an extra $20.
R.I.P. John Swinehart
Epic Mikfest 17
86 200x
85 250sx
85 big red
85 atc 70
