So I have a 10:25:1 Wiseco piston in my 200M cylinder. The motor ran just fine until I was offered a 200x head (old one had all threads stripped on everything) .. and I ended up buying a 200x cam as well. Well I put everything together to find out my intake valve was hitting the top of my piston. Checked top of piston and there was a mark in one of the indents. Found out the piston was 180 off. Wiseco said to put it one way well it was wrong because the smaller indent was on the intake side (intake valve is 2x the size as exhaust) so I swapped the piston. Put top end back together AGAIN and its still hitting. Timing is spot on, cam shaft was put in right, valves are adjusted right, everythings torqued right.. i've tore this top end apart plenty of times and put it back right and always had it start 1st to 2nd pull EXCEPT this time.
So something lies between the 200x camshaft... or the 200x head and I can't figure it out. I still have the old 200M head and 200M cam if i need to try that just to make sure.
Are the 200x valves larger OR do they drop further than the 200m head? Does the 200x cam for whatever reason make the valves drop further....
Thanks everyone
