With all the 250SX and ES carbs I've been rebuilding lately, my SX has been sitting partially disassembled waiting for the next carb to test. It's getting to be a drag having to put it back together just to putt it around. The solution!!!!!!!! An engine mockup. Hell, I have everything to make it happen EXCEPT for an exhaust system. I need a useable head pipe and muffler. They both can be in so/so shape. It won't be going on a trike but it needs to work. Rot on the end of the muffler is acceptable.
I bought a 99.00 work cart. I have an SX motor mounted to a cutoff lower engine cradle. All I have to do is mount everything up. I'm going to feed the carb with a small lawnmower tank mounted above the engine. I have all the electrics so this should be pretty easy.
This is a cheap build so the cheaper the better for my budget. SX or ES exhausts will work. Anyone help a Brother out?
This is what my SX looks like most of the time lately
The other is the start of the project.
