Results 1 to 15 of 53
Thread: Check out these LED lights I Found
    Cincinnati, OH
    3,289
    These suckers are Badass, I have two flood lights and one of the bars that is a spot light. They come from the http://www.online-led-store.com/off-...ent-s/1858.htm Came with a all stainless mounting hardware and a stand that allows it to be adjusted up or down.
    Picture of lights Will get them in the morning forgot them tonight.
    The two small floods are projected to Put out 1600 lumens at 18W EACH! And there available is either spot or flood
    I also got to take pictures of the weather pack connectors that they give you with each light.
    The one 6 inch bar is rated at 2800 Lumens at 36w And also available in either spot or flood.
    This picture is of the two fogs
    This is of the spot light
    This is them together
    Here is a Picture where we are taking pictures
    Here are the sealed beam headlights on my pickup truck.
    Here are the leds washing out the headlights almost completely the headlights on the truck
    "MR.Clean"
    Cincinnati, OH
    3,289
    Here is a picture I took of one of the spot lights inside of a stock Triz shroud.
    "MR.Clean"
    STL
    3,560
    that looks similar to what josh (mts) is running in his Z. very cool, i like them
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by JasonB View Post
    just what I was thinking.
    I think Josh paid a fortune for his though.
    Cincinnati, OH
    3,289
Name:	led sizes.jpg
    I suck at PDF's but here are the sizes and such if you wanted to mount them in different shells.
    The think that kills me is the amount of light they put off for the amount of watts they pull. Think about a 350x The lights on them are what 30/low and 35 on high? Two of the spots are 34watts and the light output is amazing.
    "MR.Clean"
    MN
    3,263
    Nice looking lights. I have a set of 27w LED's on my 200ES, 2160LM each, one is a flood one is a pencil beam, gives me really good light a long ways ahead and to the sides of me. Really nice for plowing snow in the winter and buzzing around in the summer.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    STL
    3,560
    nice set up kb! how do run those, is there a switch inline or do they run when the bike is on constantly?
    Jan 2005
    Jones, Michigan
    1,821
    That the beauty of LED lights honnerlaw. Very very bright and dont use crap for power. Thats like my stinger flashlight i had at TF.....that thing is only 1 led light bulb and its brighter than most spot lights!
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    MN
    3,263
    I wired them into the headlight in place of the high beam on the stock bulb. So when i have the headlight switch on low beam its just the stock headlight, basically like a daytime running light to meet the DNR regs here in MN of having lights on at all times. But when i need extra light in the dark then i flip the headlight switch to high beam and the stock headlight shuts off and the two LED lights come on.
    Its worked out great!
    Most race trikes are AC output to the lights. The SX and B Reds etc have a rectifier for 12V DC output.
    Apparently AC works just fine as shown in the Tri-X headlight??
    MN
    3,263
    Depends on the lights... Some of those offroad lights can take AC or DC with ATV use in mind... But if the lights are DC only a simple rectifier can be wired in. The lights i have can take 10-30v DC.
    Mar 2013
    Baldwin, Wi
    603
    Xowner,
    Are those the 4" off road lights you have? How are they after you've had some time to use them? I just ordered a set one spot one flood.
    85 Tri-z Basket Case
    Jan 2011
    South Wales Uk
    73
    I was only saying to my brother the other day about trying to fit LEDs in my TRI Z headlight surround! Remember seeing a sweet YFZ 450 in dirt wheels mag (all black plastic with blue frame?) with a led bar on the front. Fancied doing it ever since then!
    2002 Ducati 748R MY02
    2004 Beta Rev 3 270
    1986 YTZ 250 Tri Z
    198? Italjet 50 M5D Minicross
    lokisbuddy's Avatar
    lokisbuddy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    michigan, oscoda
    429
    TY so much brother... I have been wracking my brain as to how I am gonna power two lights in a 350x headlight on my 200x I think im gonna get two of the 18w bars, do those have highs and lows lmao maybe I can rig up some blue leds to accent my engine for the low beam and for the high beam I will hook up the headlights.
    200x build
    My Feedback
    The world is broken up into two very different groups of people: there are those who like me, and those who can go to hell
    Jan 2011
    Choctaw, OK
    2,755
    I just bought four of those for my SX. Two for the front and two for the rear.
