Results 1 to 15 of 16
Thread: 250sx cold start
    Feb 2014
    New London Wi
    9
    250sx cold start
    Any solutions to getting a 250sx to start in the cold? Primer???
    May 2009
    S.E. Michigan
    1,251
    Honda addressed the cold start issues by issuing a revised starter jet.
    http://www.3wheelerworld.com/showthr...ary-1987/page2
    Check post #25, I pasted all the service bulletins for the SX in this post. The cold start issue is the 3rd bulletin. I'm not sure if this "Kit" is available anymore, but you may be able to modify your original one. Search on "250SX cold start kit" and you should get some hits.
    EDIT: Here you go, FlyingW has this all figured out:
    http://www.3wheelerworld.com/showthr...cold-start-mod
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Feb 2014
    New London Wi
    9
    OK thanks. I always heard that you hook all the vacuum lines from the carb together into a four way split and that supposedly takes care of the problem.
    shovelryder's Avatar
    shovelryder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2012
    Buffalo, MN
    427
    Drill the start jet out a bit bigger.......Very easy with a finger drill. Just did two of mine and works great.
    Austin, Massachusetts
    1,591
    there is a quick fix for this issue. its called FlyingW. look him up in the search bar. he has a ES/SX/350X carb rebuild tutorial thread that will walk you through it. Or, ship your carb to him and he does it for a small fee. worth every penny.
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    Sarnia, Ontario, Canada
    3,415
    Quote Originally Posted by redsox View Post
    Highly second 'redsox' suggestion..
    Since buying one of FlyingW's rebuilds last year I've bought one more and shipped him one of mine for rebuild..
    I'll never lay hands on another SX/ES carb again..just to remove and replace! And since he does the cold start update during his rebuilding it's even better!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Feb 2014
    New London Wi
    9
    Quote Originally Posted by shovelryder View Post
    How big did you drill it out. I tried that but probably didn't go big enoughf.
    Jan 2011
    Choctaw, OK
    2,755
    Drill it to .081mm not inch but millimeters. Its a metric micro drill.
    Jan 2014
    Massachusetts USA
    782
    By the look of the 250sx carb, its similar to, if not the same as my '87 TRX250X carb. That machine has always been hard to start in the very cold as well, harder than any other bike/trike/quad I own (and there's 18 machines in the basement to compare to!). Does anyone know if the starting jet mod is applicable to my 250X as well?
    Jan 2011
    Choctaw, OK
    2,755
    The TRX250X carb is different. The SX, ES, 350X, and 85 TRX250 are QA series carbs and the only models used in this series. The 250X carb is a QB series carb and is not part of that series.
    Jan 2014
    Massachusetts USA
    782
    Got it. The plastic cover over the throttle linkage is what had me fooled. Thanks for the reply Flyingw! One of these days I'll mess with that carb, but right now I'm finishing a KDX175 restoration for a friend, and dropping a V8 in my ford ranger. After that starts the resto of my Tri-Z!
    Nov 2014
    pennsylvania
    Quote Originally Posted by Atc_200xman View Post
    Honda made a cold weather kit that has since been discontinued. What works for us is to remove air box lid and air filter, choke on, then hold your hand over intake tube until machine sounds like it wants to fire. If you hold your hand over the too long you will flood it. This is an easy way to start the machine if your electric start works. We tried changing the plug, checked the valves, cleaned the carb. All of that made no difference.
    Aug 2014
    South Louisiana
    1,915
    If y'all are just referring to the '85 model es/sx the way I solve that problem is just search for an '86/'87 model carb. Mine starts every time and runs like a charm.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Aug 2014
    South Louisiana
    1,915
    Oh, didn't realize this thread is almost a year old...
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    B-1B is offline New to the board Arm chair racerNew to the board
    Nov 2014
    Kenai, Alaska
    18
    Quote Originally Posted by Jmoozy27 View Post
    Oh Crap! You had me cracking up here Buddy!
