Ok so I got this trike in a trade and immediately fell in love. At first it wouldn't run for more than 5 minutes without dying. So I removed the carb and soaked it and blew air through every port and it ran better. It would idle for as long as you let it and it would run fast, but you would have to baby it up to speed. It would bog if you
ed the throttle. So i did a leakdown test and the upper head gasket was blown out bad. So while I'm waiting for my new gasket to be shipped I download the service manual from this site and decide to make sure everything is good. In the manual it talks about the air mixture screw and where it should be. So I adjust it all the way in and then one and a half turns out. Then I notice it has an adjustment for the oil pump. So I take the cover off and mess with that to make sure the pin lines up with the dot @ full throttle. The only other thing I did was drain the gearbox bc the previous owner had it filled up to the "fill" whole and not the "check" hole, and it looked dirty. Service manual says any API cert 10w30 motor oil will work. So I put in Mobil 5000. My gasket comes in and I get it on and start it up. Starts up on the first pull, after sitting for a month I was impressed. Mainly bc before it would take at least 4 or 5 to start it. Couldn't get it to idle by itself though. I had to stay there on the throttle to keep it alive, even after it had warmed up. Then I notice a puddle of oil under the exhaust pipe, and still steadily dripping. So what gives?? I have read that the crank seal may be the culprit, but it was just fine before I did all this tinkering. Could it be the oil pump feeding too much oil?? I would think it wouldn't even start if that was the case. But was me draining the gearbox the straw that broke the crank seals back?? This is crazy. Any help would be appreciated. Sorry this post was so long. Just wanted to eliminate the need for any questions before anyone could help.
