This may be a dumb question but does the 84 tecate have a powerband? I just got one and havent really gotten to ride
Every engine has one. Its no magical part that is inside the engine, but rather the rpm range in which the engine makes its power.
'86 ATC 250R, Build Thread http://www.3wheelerworld.com/showthr...highlight=250r
'86 "Factory Tri racing" Tri-Z http://www.3wheelerworld.com/showthr...b-Top-Tank-ect
Pile of Tecate Parts
My Feedback Thread: http://www.3wheelerworld.com/showthr...edback-for-bkm
4 stroke power (200s) vs. 2 stroke power (yz 80/84 tecate). They both have "powerbands" or peak HP at higher RPMs. The difference is a 4 stroke comes on all through the RPM range where as a 2 stroke has a "hit" or a "powerband" as it reaches peak RPMs.
In short, yes, your 84 tecate has one helluva powerband. Hold on when it hits! LOL
My 85 Tecate has one of, if not the hardest hitting power band out of all my bikes.
08 Outlaw 525s
07 CRF70
04 Harley FLHRCI
04 TRX90
03 XR650R
03 400EX- XR650R engine
02 XR100R
01 Banshee
00 XR50R
00 XR70R
99 PW50
99 JR50
96,95 Sportsman 400
95 Xplorer 400
94 Indy XLT
87 Trail Boss
86,86,86,86,86 Scrambler
86 TRX70 x2
85 ATC350X
85,84 ATC250R
85 Red Tecate
85 LT50 x2
84 XR500R
84,84,84,84,83,82,80,79 ATC70
82,79 XL500R
83 ALT50
79,78,77,77,76 XT/TT500
76,75,74 XL70
72,71,71,71 SL70
72 Harley FX
72,71,70,70,70,70,70 CT70H
72 SL100
70,69 Z50
Make sure to clean and lube it before every ride. LOL
85 Tri-z Basket Case
hello niftylittleguy;
i actually did all the development work on those when I worked at Kawi. I would say it might be referred to a light switch power band to some degree, as mentiined by others if comes on rather suddenly, not as early or as smooth as the honda 250r but unlike the honda, it was designed to be a very high perf bike right out of the box.
if it has the stock silencer and you do not need a spark arrestor where you ride, I suggest you buy a straight through silencer and jet accordingly. it will virtually eliminate an inherent ping/detonation that occasionally happens when accelerating from lower rpms. plus it will make it "bleepin" fast, lol.
always listen for pinging as you accelerate, if it sounds excessive then quit riding and try to jet it, if that does not reduce it to acceptable levels then try higher octane gas.
if the clutch chatters or squeals slightly upon release, don't worry, it IS working properly, lol.
have fun, don't kill yourself, lol.
Throw a single plane intake under a blower geared for about 12psi and slap that on a mouse and I'll show you a 4-stroke with a helluva powerband!!![]()
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
You guys suck. I guess I need to request a refund for my recent purchase of the adjustable powerband.
http://kalecoauto.com/index.php?main...TvClHZvnS7uET1
...this is what the new member restriction is suppose to catch...![]()
Barnett,,, is this what you helped to develop???
I consider the back side of this rare item to be the most valuable. Hand written notes by the late Sandpuppy101.
