The Tri-Z shock should measure 13.5 inches eye to eye. Unfortunately, they are not rebuildable, however, you can build a "Frankenshock" as described in this thread
http://www.3wheelerworld.com/showthr...-BUILD-THREAD!
Another option is to drop in a stock Warrior 350 shock with a remote reservoir. The Raptor or Banshee shocks can be made to work, but some modification will need to be done because of the gas tank placement and piggyback reservoirs.
Good luck!
Gunter glieben glauchen globen
The Good:
1985 1/2 Tri-Z - Daily Rider - Pretty much stock ( wink )
1985 1/2 Tri-Z - Custom Black & Gold, Top mount plastic tank, custom 3D printed airbox, Banshee shock
1985 Tri-Z - Rider restore in process
The Bad:
1988 TRX250R with 86 ATC 250R Motor and Swinger - Screamer!
The Ugly:
1993-ish Banshee / 2003 Motor by VSR in Belding, MI - Duner Fun!!
2000-ish Banshee / Motor by RDZ Racing in Fowlerville, MI - Another Duner!
