Thread: 86 250r Front fork seals
    Oct 2012
    Finlayson, Minnesota
    1,066
    Hey guys my 86 R has a very squishy front end! I changed out the oil for ATF and it helped a ton.. sags about an inch just sitting there and 2 inches with me on it. Used to sag about 6 inches though. The seals were leaking after pushing down on the front so they need replacing.
    I ended up buying new seals but have no clue how to install them. I have taken the spring out.. the Allen bolt on the bottom and still have no clue how to install these. Also once I replace the seals how do I stiffen these forks up? I'd rather not add air and blow the seals out again.
    Thanks for any help!
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Oct 2012
    1,066
    OK well I finally figured out the seals.. I wasn't sire if they were under the dust seals or not. Now I'm just curious as to how do I make the front end a little stiffer? Besides a heavier fluid. Or just so it sits where it should when I sit on it.
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Feb 2014
    Victoria,Australia
    878
    you can make a spacer to go under the springs to stiffen it up!!
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Poco Loco's Avatar
    May 2013
    Clap Saddle California
    389
    Cut a little piece of pvc pipe the same diameter of the springs and take your caps off and put the spacer on top of your spring and cap it off. You can adjust the stiffness with the lenght of pvc added. Just remember not to take out all the sag. You need a bit of dropout for the front end to perform right.
    Shart Guard .......Use it !
    Pink Powerwheels Barbie trike
    1985 Crash and Burn champ
    Oct 2012
    1,066
    Good ideas! i wasn't sure if i could do that.. I know what i'll be buying now lol.. some pvc!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
