Thread: 86 250r how to get seat to line up with tank?
    Oct 2012
    Finlayson, Minnesota
    1,066
    Hey guys so my 86 250rs seat is roughly an inch away from the tank.. has a nice gap.. If the gap was at the top i'd just say the plastic is bent from over the years but its the bottom to. everything seems bolted up fine and I cant adjust the tank sense there are the 10mm bolts that don't adjust for the tank. I can get pictures of everything if needed sense i'd like to remove this ugly gap!
    Thanks
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Oct 2007
    Minneapolis mn
    4,067
    Usually that gap is caused from the seat cover either being installed too tight, or a old vinyl cover that's shrunk...
    Oct 2012
    1,066
    Well the top gap is most definitely that.. but there is a gap on the bottom.. the seat doesn't touch the tank at all. Usually the bottoms touch and the top is pull backwards from vinyl shrinking. If I could pull the tank backwards.. or move the seat forward it would fit almost perfectly.
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Las Vegas, NV.
    2,507
    Cody, have you tried to see if there is any play available in the mounting of the seat to the rear fenders and/or the rear fender mounting brackets? Are these OEM plastics or aftermarket? If they are aftermarket, whoever mounted them up may not have drilled the seat mounting/fender bracket mounting holes in the proper locations.
    Oct 2012
    1,066
    Red Rider.. I actually have no plastics on it right now! Just the seat and tank. There doesn't seem to be any play anywhere.. Which is why I dont get it.. If i could move the mounting plates on the seat a half inch to an inch it'd be a perfect fit!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Las Vegas, NV.
    2,507
    With plastics on it, the rear fender plastic will get sandwiched in between the seat & mounting brackets, which I believe would make the gap slightly worse. I looked at mine, and I have about a 1/4" uniform gap in between the seat & tank.
    Oct 2012
    1,066
    hmm i'll get a picture of it tomorrow.. its more than a 1/4 inch.. I'll get some of the mounting brackets as well.. who knows maybe i did something wrong haha
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
