Thank you for your time in advance.
I will try to make a long story short.
A few months back i purchased a 1985 250R rolling chassis. It is in pour condition. It had decent factory plastics though. Lots of corrosion but must have been stored under cover for the majority of its life.
It came with a honda XR headlight and a completely corroded rear master brake cylinder. Obviously rode at the coastal dunes without a proper cleaning prior to a long time in storage.
My plan was to restore it over the next couple of years.
Looking on craigslist i found a 1986 rolling chassis for what looks to be a good deal...
I spoke with the fella who owns it and found out:
It has no front brake assembly at all, no wiring harness or kill switch. But has a nice functional honda OEM headlight.
My question is this....????
I have a 1985 honda engine. I also have the full wiring harness from the previous 1985 rolling chassis i bought earlier.
1. Will the 1985 stator power the 1986 headlight?
2. Will the 1985 front brake assembly work on the 1986?
3. Will the 1985 good OEM plastics i have fit on the 1986? I am aware of the rubber gas tank/frame protectors being different.
4. Will the 1985 forks work with the 1986? My understanding is they have a 1 degree difference as far as the angle goes.
I know about the minor differences in brake systems.
Anything else somebody can chime in about regarding putting 85 equipment on an 86 would be appreciated.
