Thread: 1986 atc250r flooding (help needed)
    Sep 2014
    minnesota
    24
    Just finished a 3 year restoration project on a 86 250r. Started it up Monday adjusted air screw and idle speed and will idle fine. rev it up a couple of times it kills and floods out. Pulled the plug (BR8) and was wet fouled dry It off it will start right back up and idle but you rev it up a bit it stumbles and kills cant make it out of first gear. Its acts like its getting to much fuel or loosing spark. every time it does this you can dry the plug off and will start back up. Carb is a Keihn PJ 34mm and very clean with a 145 main 42 pilot 1468 needle. stock exhaust What I am is missing? any suggestions
    Las Vegas, NV.
    2,531
    Did it run fine before the restoration? Is this the same carburetor? Is your carb float sticking?
    devore,ca
    1,054
    Float may be sticking, or set too high. choke stuck on maybe ?
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Slidell, LA
    4,738
    Carburetors are a step by step process. I always get the pilot correct then work the main, then fine tune with the needle.
    Start it up, get it idling and bust out the screwdriver. Rule of thumb is air screw <1 turns, pilot is too small, >2.5 turns pilot is too big. Seat the air screw. How many turns out is the throttle very crisp (revs out quick and come down to idle fast)? Report back with your findings so we can at least help you determine if the pilot is correct.
    MPDano's Avatar
    MPDano is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2014
    The float is stuck. Whenever I rebuild my carb. I always verify this piece. To test (carb should be clean), connect a short clean host to the fuel inlet, with carb in upright position with bottom cover off, blow air with your mouth in the tube, it should flow free, continue blowing and move the float upward and it should stop letting you blow air. My float adjustment baseline and I usually never need to adjust it afterwards, flip the carb over and the float in it's closed position should be level with the carb (where the upper and lower carb pieces are joined).
    Hope this helps.
