Thread: Help please. Gen 1 250R and front wheel spacers
    MPDano's Avatar
    MPDano is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2014
    Putting my front wheel back on and the spacing looks incorrect. To where I can't mount the brake caliper back to the fork, it's about 3mm off. I put the longer spacer on the left side and shorter on right.
    The strange thing is that the service manual doesn't even mention the spacers.
    MPDano's Avatar
    Sep 2014
    Ok, I am an idiot. Just slid the wheel toward the caliper and it lined right up.
    I still got this large gap on the left side. Is this normal? Do I just put the nut on and tighten till it squeezes together? Seems like a lot of space.
ID:	201577Click image for larger version.
ID:	201578Click image for larger version.
ID:	201579Click image for larger version.
    Apr 2002
    s.w. michigan
    6,498
    Yes, pull your forks together as you tighten the 4 pinch bolt clamp. I snug them and tap the fork with rubber mallot.
    Just so happens I have my front tire off for a bead leak repair (again,,,,)
    Jul 2012
    Grand Rapids, MI
    997
    No 4 bolt pinch clamp on a first gen, John Just a threaded axle. And it sucks.
    Both of ours have this odd spacing as well.
    Short spacer on the brake side, long on the open side. That's the only way ours line up.
    1984 ATC 200XR
    1984 ATC 300R
    1983 ATC 88
    Feedback for Mike Pargiello
    Apr 2002
    s.w. michigan
    6,498
    Oh chit ! I had 83/84 R on my mind. So do you just pull them together ???
    MPDano's Avatar
    Sep 2014
    Thanks guys. Just tightened the nut down and it pulled the forks together. Put in a cotter pin, done. Just strange that it has that much space untightened.
