Thread: Hondaline brackets are done and they fit as expected Better pics
    Marty is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2007
    Mesa, Az
    644
ID:	204047Click image for larger version.
ID:	204044Click image for larger version.
ID:	204048Click image for larger version.
ID:	204045Click image for larger version.
ID:	204031Click image for larger version.
ID:	204046Click image for larger version.
ID:	204032It only took me 4 hours to install but brackets , tank have been installed. The only change I will recommend will be making the bolt hole bigger on the lower oval bracket to retain the stock OEM bolt. Thanks Andy but he was correct with his findings, 1986 "L" shaped bracket WILL fit but rest of brackets came out accurate. They all fit well but I also will recommend size bolts will be needed for lower and upper brackets. But here are final pics and no I do not have the lower tree it came out really coolClick image for larger version.
ID:	204032Click image for larger version.
ID:	204031I will post better pics in the morning thank Wyan, Andy, Scott and a few others I may have forgot for help and comments, or direction to go with this project.
    Qdude79 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    CenCal
    369
    What brackets are you referring to?
    "Still occupied with 1985"
    200X- restored to near original and SOLD
    350X- back in black
    250R- she purdy...
    Nov 2007
    Mesa, Az
    644
    brckets
ID:	204036Click image for larger version.
ID:	204037Click image for larger version.
ID:	204038Click image for larger version.
ID:	204039Hondaline short course brackets I had remade
    Ripley Tn
    1,363
    were you able to use the stock hose's
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    House Springs MO
    5,496
    Quote Originally Posted by motoman1012002 View Post
    I use the stock hoses with mine.
    Nov 2007
    Mesa, Az
    644
    yes I retained stock hoses!
