Just getting things together for a 426 conversion over the Christmas holiday's and was wondering what offset 10" rim can be run on a Tri-Z front hub? Going to be machining the hub to run the 10".
Thanks in advance.
Thanks in advance.
Do you think a 10X5, 3+2 offset, 4/156 will work? The original rim is a 3+3.
What front end are you using is the million dollar question, custom forks triples ? Or what ?
"MR.Clean"
I would use a 250r front hub so you don't have to machine the hub, also if your using the triz forks you have to cut the mount off and move it down and use a smaller rotor.
I have 10 inch 3-3 offset 4x170 to fit the 250r hub with not mods
"MR.Clean"
Using the forks off the bike with vtx1800 triple.
Will the Honda hub fit the Yamaha front axle? Also are those rims available in black?
The honda hub does fit the yamaha axle im pretty sure. Sorry i dont have black.
"MR.Clean"
No biggie. I can get it powdered. How much shipped to Calais Maine?
Pm sent .
"MR.Clean"
