Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: Flat Track/Short Track, Kart Wheel Adapter Feeler
    Buffalo, NY
    1,994
    Forgot the picture.
    House Springs MO
    5,496
    there is a lot easier way to do this!!!
    they will run true and be able to run different length offset hubs
    Care to elaborate?
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,244
    let me build a set ,, I will show you what I mean,,,, sorry for leaving you in the dark!! I have a set of hubs and I will get pictures up tomorrow if I get the chance,,
    KASEY's Avatar
    4,244
    here are the hubs in different offsets,,, when you get into the gokart stuff the possibilities are endless!!! kick ass brakes and hubs and discs too!
    oile's Avatar
    oile is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2012
    kansas
    600
ID:	205288 Here's a Tri z with kart axle,rotor and sprocket hub.
    House Springs MO
    5,496
    The Kart stuff is the Bees Knees with endless possibilities for gearing and width changes. There is a member on here that is getting a 250r setup that should be bolt on and should be around $300 minus tires and wheels. I'll let him chime in if he wants.
    The adapters I'm making will allow a guy to simply bolt them on the stock hubs and run little tires, then go right back to their previous setup. No modification to oem components.
    Since my bike is now a dedicated flat track bike, I will be eventually switching to the kart axle setup. For a single use bike they are the way to go.
    Jul 2012
    Joplin, MO
    597
    Fasteddie has done a lot of research on kart axles. His original design was turning down a stock axle and plug welding a kart axle on it. That didn't turn out to be the best way because it still had a weak link.
    Then after more searching he found bearings for the 1 1/4 axle. He had to do some machining on his carrier to make it all work. He got it to work. Look up Ashtabula race.
    I have talked to him quite a bit and done some research as well. I looked at the 40mm kart axle and asked Eddie and a friend that has a kart shop in town and the wall is too thin and parts aren't as easy to get. The main part is the bearings and he figured what to use.
    I have some parts odered that if it all works, I can use my bigger wheels and and change over to kart wheels just in minutes.
    I am using a 450 swinger and the parts will work the same on an R.
    If it works like I think it will, there should be little or no modifications.
    I will post up pictures and details when I'm done.
    Sent from my LG-US780 using Tapatalk
    Jul 2012
    Joplin, MO
    597
    As far as the easiest way, the hub adapters simply bolt on and take off.
    Jul 2012
    Joplin, MO
    597
    Feb 2008
    (southern) Wisconsin, USA
    974
    Cool stuff for sure, but beyond my intentions. Honestly, I'll probably never even use what Brian is making. Iowa is pretty close to Wisconsin so never say never. Given the opportunity to buy what's needed at a minimum of modification, I'm gana go with Brian's hubs. Very neat Kart parts though guys! Plenty of options and purpose intended set ups. Just over kill for a wana'be racer like me. Thinking 4" adapter hubs on each side will be best. I can adjust stagger with the axle shaft collar spacers, and simply run a West Coast hub on the right. And if for some reason I don't want stagger I'm set. Thanks B!
