Results 1 to 11 of 11
Thread: Hydrographics (water transfer film process)
    Miami,Fla.(305)
    808
    Pretty neat-any of you try it? Very simple process- though this guy doesnt explain it or show it all- but theres many other videos explaining it: https://www.youtube.com/watch?v=Bc0rfGRv3xg
    Ive seen just about anything done: frames,rims,tanks(plastic& metal) works on wood,ceramic,bone,too)
    Look up "Hydrographics. " Theres a few companies (on EBAY too) selling starter kits $70-$100 great for trying it out before going to a professional set-up with sprayer & fancy dip tank.- In the tank is just plain water & you can use any plastic tub really!
    This NOT same as "plastidip"
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Apr 2010
    Cold Lake, Alberta, Canada
    537
    With some practice you can do it no problem, but it isn't as dip and dry as shown. There are many factors to consider when dipping and techniques to use. If you mess up, it's a long process to start over. Other than that, it's good stuff.
    You can view a build with hydrodipped commo theme here..
    http://www.3wheelerworld.com/showthr...amo-US90-Build
    [B]
    Trikefest Alberta: 2017, 2020
    Trikefest 2015 A.K.A MUDFEST
    Coolpool: TURN!
    Mexico
    9,014
    Yea, tried it. Looks great, but its starting to come off my rad shrouds where they flex.
Name:	t post yamaha stephanie 080.JPG
    It sucks to get old
    Nov 2014
    Paris, Tx USA
    100
    I used to do it professionally. It is the same process as painting a car with the added step of film dipping. It's not as easy as the videos show. You can expect to go through a lot of film until you are able to get a good dip. If you're dip is no good, you have to wet sand to base coat then start over.
    Good adhesion to plastic is critical. We tried the adhesion promoters and had best luck with flaming the plastic.
    Not saying you can't DIY it. Just be prepared for an adventure.
    Flaming the plastic ?
    Nov 2014
    Paris, Tx USA
    100
    Quote Originally Posted by big specht View Post
    With polypropylene and polyethylene plastic, the paint will not adhere. You take a propane torch with a fan tip and move the blue part of the flame over the plastic quickly as if you're "painting" it with the flame. Then you wipe it down with 90 percent alcohol. This oxidizes the surface of the plastic. You can then prime and base coat.
    The best torch to use is one made for shrinking heat shrink film.
    May 2003
    Houston, Texas
    2,409
    Quote Originally Posted by e5earley View Post
    This is excellent advice! I am going to be sealing and painting and tank and will do this!!
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Mexico
    9,014
    Thanks for clearing that up e5, things were looking to get weird in the shop!
    It sucks to get old
    Nov 2014
    Paris, Tx USA
    100
    Little too much flame there. But I'm certain he could make it look "Fabulous!!!"
    Mexico
    9,014
    Ok, I think I'm understanding now. So this would be as far as one would be to get maximum adhesion?
    Seriously though, that explains a lot. I wonder what the OEM's do for prep when they put camo on an entire quad, or is the plastic blended to suit the process?
    It sucks to get old
    Nov 2014
    Paris, Tx USA
    100
    I'm not sure what their process is. I do know that there is some equipment that treats plastic for painting using electricity.
