I just bought 85 Tri-Z 250 and I started it up but its leaking through the over flow hoses. You guys think it's my floater getting stuck or debris in my carb? What do you suggest?
Check your needle valve. If there is a small wear ring or groove around it, replace it. Verify your float "floats" as well.
85 Kawasaki KLT 160
85 Kawasaki KLT 110
82 ATC 70
2000 Scrambler 500
Ok will check when I take it apart this Saturday. Thanks I'll port pictures.
Let me guess...a mikuni?
bad float needle valve
http://www.3wheelerworld.com/showthr...3-float-height
86 T3
84 T3
86 KX250
It's a larger kiehn carb. Took it apart the inside was dirty. Sprayed carb cleaner and put it back together. Not one drop of gas. Thanks guys for the help!
