Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: Proper Compression on a 1982 Honda 250R?
    MPDano's Avatar
    MPDano is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2014
    The rest of the pieces arrived. Took plenty of pics before I dropped it off at the machine shop with the piston. Getting it bead blasted as well to remove all the red paint. Gonna high temp clear over the clean metal.
ID:	211276Click image for larger version.
ID:	211277Click image for larger version.
ID:	211283Click image for larger version.
ID:	211282Click image for larger version.
ID:	211281Click image for larger version.
ID:	211280Click image for larger version.
ID:	211279Click image for larger version.
    Winnipeg
    211
    I just checked mine.. 105 PSI.. but starts good and runs good! am I losing that much power?
    MPDano's Avatar
    Sep 2014
    Got my Jug back from the machine shop yesterday. Going to install it today. What are the torque specs on the jug and head?
    Also, arrow on piston points toward exhaust, correct?
    Thanks,
    Leo
    bigdaddyvw185's Avatar
    bigdaddyvw185 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2013
    Seymour CT
    314
    torque specs on the cylinder head are 17-21 ft lbs, jug are 27-35 ft lbs
    and yea arrow on piston towards exhaust
    Connecticut
    1,605
    Quote Originally Posted by MPDano View Post
    Thanks,
    Leo
    Cool your top end is machined, glad you are making progress!
    Winnipeg
    211
    just checked mine 141 PSI..
    is there a big difference in power from 140-160??
    I can pull the front wheel in third!
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by bigdaddyvw185 View Post
    Awesome! Thanks for this. Didn't get much done today as my son had his First Reconciliation at his school/church, had lunch and it was so warm out, I passed out on the bed. Must have been exhausted from the work week. Gonna pick this back up in the morning.
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by sledcrazyinCT View Post
    Thanks. Gonna get some pics up as soon as I can. I'm a perfectionist and the bead blasting wasn't perfect as there was a little bit of red left behind. Anyways, hit it with some Engine Clear and moving on. Bore/Hone look awesome tho.
    82 250r's Avatar
    82 250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    Utah
    278
    Quote Originally Posted by wpginterceptor View Post
    just checked mine 105 PSI..
    Which is it?
    Winnipeg
    211
    Have a Chinese tester and got 105.. used better tester and got 140!
    Make sure you do a proper break in! VERY VERY IMPORTANT
    do your heat cycles.. run 20-1 mix, USE GOOD 2 STROKE OIL
    MPDano's Avatar
    Sep 2014
    Got some time to do the re-assembly. Roller Bearing I bought was the wrong size, mine was a bit larger. Anyways, mine was in good condition so I re-used it. Used Assembly Lube on the bearing, piston rings and shaft and cylinder walls. Got it all together and did a quick compression test and 170, now that's a whole lot better. Should get better once the rings get seating in.
    I also replaced the 150 main jet and put a 155.
    She fired up on the 2nd kick. I also took a quick video, smoke is burning off all the lube. Took a quick spin around my yard and adjusted the a/f to 2-1/2 turns from close. I can already feel the new power I got from that overbore. Can't wait to get it out to the Desert and open it up.
    MPDano's Avatar
    Sep 2014
    Winnipeg
    211
    make sure you do heat cycles.. and retorque the head! drive it like an old lady for a while!
    MPDano's Avatar
    Sep 2014
    Will do. For the record, the extra compression really wrenched my right ankle when i went to start it up a few hours later to show my wife. Swoll up like a balloon.
  15. #30
    Winnipeg
    211
    tell me what compression is after a few hours of riding
