Results 1 to 10 of 10
Thread: 200x swingarm pivot bearing.
    wisconsin
    146
    having a hard time getting these rust-welded bearings out. anyone have any ideas? ive tried heat and a sledge. and that just broke the edge of the outerbearing race apart. also, i remember seeing delrin 200x bearings in the 3WW store but cannot find it anymore. anyone have info on that?
    Aug 2014
    South Louisiana
    1,915
    You basically have to get a section of the cylindrical race cut out to loosen it a bit. I used a reciprocating saw to get the cut started then finished the job with a chisel and .
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Slidell, LA
    4,738
    Quote Originally Posted by jrooster View Post
    First I try heat and a blind hole puller. If that doesn't work then I get my dremel out with an aluminum oxide grinding stone (pointed style) and begin grinding down the inner bearing surface little bits a time. Eventually, you have it thin enough where you can stick a tiny screwdriver between the housing and the outer race. I pry out until I get a bend in the bearing and then use a pair of small vise grips to get a good grip on the bearing and twist until it pops out. Takes patience but it works for me every time.
    Once you have one side out, get a deep well socket with the same diameter as the outside race but small enough to fit inside the front housing. Sit the swinger on 2 2x4's, slip an extension on the socket and slide the socket and extension through the housing. Heat the bearing side you want to break lose and give it about 3 good whacks. Those bearings come out like butter.
    I haven't seen 200x Delrin bushings offered for a long time. I wish somebody would start making them again.
    House Springs MO
    5,496
    I'm going to be making the 200x delrin bushings. I've been waiting on some tooling and honestly have been busy as hell lately. I should have something ready this week for jmoozy to test for me.
    Aug 2014
    South Louisiana
    1,915
    Got a '84 swinger on standby for those bushings, Bryan. Btw, those shelves look nice...
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    The Open Road
    4,736
    I was going to turn some bushings to sell but I thought DC mentioned he was too...or maybe it was BKM.
    I decided not to because I don`t want to step on any toes unless the demand is too great.
    I'm in the middle of making 30 350X headlight guards and then a dozen 250SX guards so the Delrin is up for grabs!
    I don't wanna promise something I can't do. I lost a phase on the lathe yesterday so I have to see if I just lost a start capacitor, relay or the 3rd phase itself. I have to get back my mega-ohmm reader to test the windings.
    I don't need the lathe for the guards. But, I'll be out of metal today, gotta order 2X as much as usual.....
    toki is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2011
    wisconsin
    158
    Question. I was looking at making my own delrin bushings for a different project (74 TY250 and my 83 250r) on my atlas... do you guys use an oil impregnated delrin or just regular delrin?
    I routinely spill Hot McDonalds coffee in my crotch, just to ease the numbness of everyday society..
    Oil imp or UHMW
    Jul 2011
    wisconsin
    158
    Thanks for the info!
