Results 1 to 15 of 19
Thread: Parts washer fluid, what are you guys using?
    Surprise, AZ
    2,428
    I used to use diesel fuel and liked it but it stinks up the shop.
    I changed to Simple Green which is OK and I like the smell, but there must be something better or maybe a concoction?
    Cheaper the better because I like to change it often.
    Aug 2014
    South Louisiana
    1,915
    1 part diesel, 1 part ATF = this stuff really stinks, but it works.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Feb 2015
    Cairo NY
    55
    I like individual cans of brake cleaner. The flammable kind. Especially Just before final assembly, all parts are blown clean. For heavy grunge, I scrape it off, then use blue-rags-in-a-box with brake cleaner. The rags then go in the fireproof metal can to be used to start the shop Woodstove in the winter. I tried parts washers, I never trusted the fluid, seemed like it carried dirt back on to the parts I wanted clean.
    poolieZerUK is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2013
    Hartlepool UK
    150
    If you are going to mig or tig weld you have to be careful what's in carb and brake cleaners there's some chemical reactions that can make mustard gas when burnt with argon will really feck you up good and proper
    Have a quick search on the web to make sure
    Mar 2007
    Texas
    5,045
    I like to use purple power. 1gallon is like $18.99 at the auto parts store. let it soak over night and 90% of grime is gone. then use a brush and get the hard stuff off. parts look nearly new. if you have metal, use CLR to remove the rust and it will look new again after you cleaned.
    ________________
    https://www.mikesatvfix.com
    NEPA
    7,051
    Same here^^^ However,last time I bought it at Wal Mart or Auto Zone it was $4 a gallon? I won't buy the name brand,only the knock off. Put some in a sams spray bottle.Dillute it about 1/4 purple/3/4 water. spray on your bike before washing. For parts cleaner,,,full strength,,USE GLOVES,It WILL eat your skin off. Are there stronger commercial heavy equipment degreasers? Yes, But for the price, this is the best I've found by leaps and bounds.
    Mineral spirits are in mine the zep guy tryed to talk me out of it but his stuff was like 30.00 a gallon. He said it would stick the shop up but we don't notice it at all
    Surprise, AZ
    2,428
    Quote Originally Posted by ponderinjunkman View Post
    I scrap/wire brush the parts very well then put them in my 20 gallon parts washer, I have a filter on the pump so the junk stays at the bottom under the cleaning rack. I also built a bubbler system I can install that works on very low air pressure to "boil out bad parts"
    Thank You for all of your input.
    I did a grim test tonight- Simple Green VS. Purple Power VS. Pinalen.
    Pinalen won hands down...Hmmm
    I also spray off everything with carb. cleaner, outside. I buy carb cleaner by the case.
    Surprise, AZ
    2,428
    Quote Originally Posted by Jmoozy27 View Post
    I like this, but my wife can smell a neighbors fart from 2-clicks away so I am going with water base VS. oil base.
    Plus I have been building trikes/bikes/quads/hot rods for so long I already "Glow" at night from the harsh chemicals!
    Scootertrash's Avatar
    In the sticks
    4,638
    Quote Originally Posted by onformula1 View Post
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Quote Originally Posted by poolieZerUK View Post
    YES! Good and proper warning to all, brake cleaner has an ingredient that when submitted to ultra violet light (Like from welding...) produces phosgene gas, which is indeed basically Mustard gas, bad bad stuff. Its not even the heat that causes the reaction, but the brightness and type of light emitted by the welding process. Carb cleaner does not have this issue from what I understand (I have always used carb cleaner since I learned of this).
    For cleaning parts...I've never really had good luck with anything but Purple Power and carburetor cleaner myself. What is Pinalen?
    NEPA
    7,051
    What he said^^ What is pinalen? And btw,,I bought a gallon of simple green at Sams,,SO WANTING it to be awesome,,My experience is it makes a nice cologne and works like tap water. WHAT grease will it remove?? Because it sure doesn't remove any of my kinds of greases!
    Aug 2014
    South Louisiana
    1,915
    This is how I clean my parts...
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    House Springs MO
    5,496
    Pinalen is concentrated pine oil cleaner available at Wal-Mart I believe. I have a buddy who swears buy it and purple power.
    Dec 2012
    Norfolk, Va
    135
    Mineral spirits
    85 250r
    ESR 310
    09 Raptor 700
    07 LTR
