1985 Tri Z - Next project!
1982 250r - Sold
1983 Auto X - Sold
1984 Auto X - Sold
1985 200M - Sold
1985 YTM 125 - Sold
1985 185 - Sold
1984 185 - Sold
Check out my feedback:
1982 250r - Sold
1983 Auto X - Sold
1984 Auto X - Sold
1985 200M - Sold
1985 YTM 125 - Sold
1985 185 - Sold
1984 185 - Sold
o-rings won't bump compression. Just an advanced way to seal the head. Looks great!
Depending on how the system is set up and installed, in many instances, if you used a 2 O ring system similar to the one below, and it no longer has the standard head gasket which is around .028” thick if I remember correctly, AND the head you are running is orig or has the same or less volume as the orig, you raised the compression by at least .5 [1/2 a point] . . Also, unless it has a recessed squish band the piston will likely be too close to the head at tdc especially when it’s running.
If your exhaust port was raised when it was ported, this will reduce the compression, therefore if the O rings increased the compression and the exhaust port was raised which will reduce the compression the two mods will cancel each other out to some degree.
The most important thing you can measure is static compression . . If it is less than around 140, it is pretty wimpy for high perf apps . . If it is around 170 or higher, it is very good.
Motor looks great!
What color/paint did you use for the motor?
Looking great.Im thinking of having my motor done by bdt with a 68 mill piston and port .
250r rules
Thanks guys! I still havent got the color name haha.. Barnett that was a nice little bit of info so thanks! I was told it will bump it up just a tad like you said. So what is static compression?
atc300r.. I highly recommend it! You definitely wont be disappointed.
1982 250r - Sold
1983 Auto X - Sold
1984 Auto X - Sold
1985 200M - Sold
1985 YTM 125 - Sold
1985 185 - Sold
1984 185 - Sold
1982 250r - Sold
1983 Auto X - Sold
1984 Auto X - Sold
1985 200M - Sold
1985 YTM 125 - Sold
1985 185 - Sold
1984 185 - Sold
no prob, you're welcome . . yeah, changing the distance from the piston to the head more than .010" in any vehicle will make a measurable change . . Changes of .040" or more can be felt.
it is the amount of compression an engine has when just being turned over by the electric starter or kick starter.
the test should be done with the throttle at least 1/2 open . . it is also called uncorrected compression.
the compression while it is running is called corrected or dynamic compression . . dynamic is the most common term.
the compression will vary slightly with engine rpm which is why its referred to dynamic . . dynamic basically means moving or changing.
haha yea no i'm sending the head out to get worked on.. 230 would be awesome but no thank you.. i want pump gas
1982 250r - Sold
1983 Auto X - Sold
1984 Auto X - Sold
1985 200M - Sold
1985 YTM 125 - Sold
1985 185 - Sold
1984 185 - Sold
Yea I told him I only want to run 91.. thats the only thing I can get around here.. no 93 or 94 anywhere that I know of!
1982 250r - Sold
1983 Auto X - Sold
1984 Auto X - Sold
1985 200M - Sold
1985 YTM 125 - Sold
1985 185 - Sold
1984 185 - Sold
