Results 1 to 9 of 9
Thread: ***1985 Honda ATC 350X_Help Please***
    Jan 2014
    Pittsburgh, PA.
    31
    I cracked my rear swing arm bearing carrier 30 minutes into Trikefest 2015...back home now looking on the internet for a new upgraded bearing carrier that'll fit perfectly on the rear swing arm of my '85 honda atc 350x and I can't find squat...anybody have a link or a clue where I can get one...and some new rear carrier bearings too!! I was the guy with the monster quad down by the stagnant lake!!
    85' Honda ATC 250R - Showcaser
    85' Honda ATC 250R - Black Beauty (under extreme renovation..official unveiling at TF 2015!!)
    85' Honda ATC 350X - Tree Trunk Prowler
    15' Can-Am Outlander 1000 XMR Digi-Camo - Muther F'r Jones
    **Head'n to Trikefest 2015**
    Slidell, LA
    4,738
    I am pretty sure the carriers are the same for 85-86. At least Honda has the same part number for both years. 86 carriers are plentiful on eBay. But if you have to go with 85 I pasted an OEM one below.
    http://m.ebay.com/itm/1985-HONDA-ATC...882?nav=SEARCH
    House Springs MO
    5,496
    They are different between the two years. The aftermarket carrier available is actually for a 300ex but will work on the 86 350x. You can use it on the 85 350x, but a 86 rear sprocket and tapered sprocket bolts must be used.
    Sent from my SCH-I535 using Tapatalk
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by PittsburghPete View Post
    Go to google.com
    Type in Honda 350x rear axle carrier photos
    You will see 3 or 4 different types there/ . . they are aluminum . . see if any are machined from billet aircraft grade aluminum.
    You can likely get nos bearings from cmsnl.com . . if not, they may list the bearing style like 6003 or 6005 etc . . look for that number on eBay and bearing supply places . . I would not. Buy cheese bearings
    Jan 2013
    minnesota
    5,911
    OK, radmfg.com makes an 85 with the flange and an 86 one . . both are t6061 billet aircraft grade aluminum. . they also have double row besrings
    Jan 2013
    minnesota
    5,911
    Lol its Chinese bearings, not cheese bearings but I would not buy those either
    House Springs MO
    5,496
    The RAD carrier for the 85 is $219.99. I wasn't aware of any company that sold one for the 85 until now. This is an option if you don't want to bother with swapping the sprocket and the hard to find 86 bolts.
    Jan 2014
    Pittsburgh, PA.
    31
    Just placed the order on radmfg.com and got the brand new bearing carrier and bearings all to my door for $280.00. Can't wait to get this 350x back in the running. Thanks everybody and a special thanks to BKM!!
    House Springs MO
    5,496
    Just making sure you didn't order an extra set of bearings you didn't need? That rad carrier comes with the bearings installed.
