Page 1 of 9 1 2 3 ... LastLast
Results 1 to 15 of 124
Thread: 1985 250SX Resurrection
    Jun 2015
    Arizona
    69
    I picked up a '85 250SX a few weeks back for basically $100. It had been sitting neglected for a few years in the back field. PO decided to put it on Craigslist with a little pull behind trailer so I nabbed the whole lot for $200. He said it had not ran in a year but with the condition everything was in and how disintegrated the front tire was I am willing to bet a few years. Either way the motor turned over with good compression so I took a gamble. I only got a bill of sale and until the title process was finished I wasn't putting one finger on it in case someone tried to claim ti during the process. Luckily though no one did and now its all mine with a clear title!
    I was not sure of the full condition of the motor so I did the bare minimal to see if it would run. Changed the oil and filter. cleaned the carb, put some deep creep in the top end to lube it up a bit and a new spark plug. I grabbed the battery from my XR650L and a quick prime and a second on the starter button and it fired right up! I even got a video of it starting for the first time in years.
    Well it fired up and ran so its all fair game now. First with the cleaning.
    This was the day it came home
    Cleaning the carb. Man this was some of the thickest turpentine Ive ever seen. Pull the slide up and it just sat there slowly sliming its way down.
ID:	218369 Click image for larger version.
ID:	218370 Click image for larger version.
ID:	218371 Click image for larger version.
ID:	218372 Click image for larger version.
ID:	218373 Click image for larger version.
ID:	218374 Click image for larger version.
    After the cleaning. I didn't put no new parts or gaskets in because I didn't want to put any money into this if it was shot.I got lucky as you can see in the video the carb held together and didn't leak.
ID:	218376 Click image for larger version.
ID:	218377 Click image for larger version.
ID:	218378 Click image for larger version.
    The initial cleaning was a ton of work, a couple cans of degreaser two brushes and a lot of elbow grease.
ID:	218380 Click image for larger version.
ID:	218381 Click image for larger version.
ID:	218382 Click image for larger version.
    Her former glory is starting to shine through after all these years.
ID:	218385 Click image for larger version.
ID:	218386 Click image for larger version.
    Jun 2015
    Arizona
    69
    Along with cleaning her up I also made a quick trip down to Tucson and scored a 1985 250SX motor with harness, controls, carb, exhaust, airbox and rear swing arm assembly with drive shaft for $150. The plan is to rebuild that motor down the road and then swap it out.
    Since the motor checked out with 160lbs compression I went on a shopping spree for this old girl.
    Carb rebuild kit
    UNI Filter
    New battery
    New Red Maier plastics
    New petcock
    New Clarke tank
    New seat foam
    New seat cover OEM style
    New PRM-ATV Grab bar
    OEM style sticker kit
    New10x5 ITP steel front wheel
    New 9x9 ITP steel rear wheels
    Duro Thrasher front Tire 23x7-10
    CST Ambush rear Tires 22x10-9
    Pro-Taper SE 7/8" ATV High Bend Silver bars
    New front brakes
    New steering stem bearing
    New front wheel bearings
    Fork seals and oil
    Some new grips
    and some small misc OEM replacement parts.
    Thinking about maybe taking the rear shock out and down to ZR1 Suspension and having him rebuild the shock and maybe install a heavier spring since I am viking sized anyways.
    Feb 2013
    Senoia, Ga
    635
    That's a pretty sweet price. It's a lot nicer than the one I bought back in 13.
    That's a killer list also. Those items are gunna make that old SX bling!
    Make sure to keep us updated on your progress.
    Jun 2015
    Arizona
    69
    Upnatm it's actually your build thread that I got most of my ideas from. All the way down to the HRC decals, I love those.
    So credit for the ideas of this forth coming build mainly goes to you.
    “The world is a book, and those who don't travel read but one page.”
    ― Augustine of Hippo
    My 1985 250SX Resurrection thread
    Current Stock
    1985 Honda 250SX
    1988 Honda Fourtrax 300
    2008 Honda XR650L
    2003 Suzuki DR200SE (wifes)
    MOTOVIKING
    PMA4X4
    Jan 2011
    Choctaw, OK
    2,755
    Nice score. The SX is my favorite trike. I've done ground up rebuilds on several. That's the one they will pry from my cold dead hands. My daily driver is the one with the white star. The others I've sold.
Name:	85 ATC250SX (Section 8) (1) (Copy).JPG
ID:	218394   Click image for larger version.
Name:	1985 ATC250SX (Above the Law) (1) (Copy).JPG
ID:	218395   Click image for larger version.
Name:	100_0458 [1024x768].JPG
ID:	218396   Click image for larger version.
Name:	100_0198 [1280x768].JPG
    Jun 2015
    Arizona
    69
    I thought about doing other color schemes but decided to stay with the original 85 red.
    Flying w are you any where else? Your name sounds familiar
    Sent from my Nexus 5 using Tapatalk
    Current Stock
    1985 Honda 250SX
    2008 Honda XR650L
    MOTOVIKING
    PMA4X4
    Jan 2011
    Choctaw, OK
    2,755
    I was a moderator at 3WO for years. I'm Baldwin JRB on Facebook and I'm a riot at parties.
    Jun 2015
    Arizona
    69
    Found ya!
    Its going to be a long week waiting for parts to show up.
    Jan 2011
    Choctaw, OK
    2,755
    If you need help on anything, give me a shout. You can always get me at jamesbaldwin99@gmail.com. I rebuild the ES/SX carbs and differentials. I have a tutorial on both here if you need information.
    http://www.3wheelerworld.com/showthr...54#post1257154
    http://www.3wheelerworld.com/showthr...54#post1282554
    Feb 2013
    Senoia, Ga
    635
    Quote Originally Posted by themotoviking View Post
    Thanks man, it was a fun build. Actually, without the help from the folks here on this site, like Jim, it would have been a lot harder to finish. I sorta wish it wasn't done, and I was still working on it.
    It's been a while since there has been an sx build thread here, so I look forward to watching yours unfold.
    Jun 2015
    Arizona
    69
    Quote Originally Posted by Flyingw View Post
    Nice write-ups! Picture are what make them possible. I did similar of on some chevy truck forums and they got pinned to the top they were so detailed.
    I'll be using some of your carb thread for sure this week and the diff thread when I attack the rear end. GOD I LOVE DETAILED WRITE-UPS!
    Does rubbing alcohol,really work? Does it break all the dirt and hardened gas down? Never thought of using that before.
    Jun 2015
    Arizona
    69
    You go well above and beyond what I normally do for a carb cleaning and rebuild. Just curious what you charge for the carb service? Do you have a carb to ship out and I send you mine in than? If not whats turn around time?
    Jan 2011
    Choctaw, OK
    2,755
    I use 99% Isopropyl alcohol (technical grade)for many things. For the carbs, It dries out any residual varnish, dirt, or whatever is on the carbs. It makes bead blasting the bodies and bowls go faster. My cleaning process is done in several steps but the final step is to shoot carb cleaner through all the holes in the carb. I prefer to soak the carbs in Heptane but that stuff is a little spendy. Alcohol works pretty good and it doesn't leave any residue behind. I also use alcohol to clean and degrease parts prior to powder coat. Isopropyl alcohol has many uses. I buy it by the gallon on Ebay.
    Jan 2011
    Choctaw, OK
    2,755
    I charge 95.00 for my rebuild services. I have done dozens of the ES/SX/350X carbs so I've got pretty good at it. My turn around time is only a couple of days but most of the time I try to get them back in the mail the next day. Right now I'm out of ready to go carbs but I am more then happy to give yours the love it needs. I have plenty of spare parts if I need to replace anything. I do all my carbs the same way every time and it seems to work.
    Jun 2015
    Arizona
    69
    Ok Ill have to see if I have that lying around. As you can see from my list I went on a spending spree plus the spare motor I just bought has kind of left me stripped of play money.
