Page 5 of 9 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 61 to 75 of 124
Thread: 1985 250SX Resurrection
  1. #61
    Jun 2015
    Arizona
    69
    I have the original rear fender If anyone is interested, no breaks in it just sun faded. No hardware is included $160 and that includes shipping within the lower 48 states.
ID:	218769 Click image for larger version.
ID:	218770 Click image for larger version.
ID:	218771 Click image for larger version.
ID:	218772 Click image for larger version.
ID:	218773 Click image for larger version.
    “The world is a book, and those who don't travel read but one page.”
    ― Augustine of Hippo
    My 1985 250SX Resurrection thread
    Current Stock
    1985 Honda 250SX
    1988 Honda Fourtrax 300
    2008 Honda XR650L
    2003 Suzuki DR200SE (wifes)
    MOTOVIKING
    PMA4X4
  2. #62
    Jun 2015
    Arizona
    69
    Rear end on the bike itself was in pretty good shape except for the diff. It appears someone has already been in here and didn't do a proper job probably resulting in this "hand grenade"
    Brake section almost looks untouched from factory.
ID:	218777 Click image for larger version.
    Splines and seal surface look really good. Looks like I can still use this current axle shaft.
ID:	218779 Click image for larger version.
ID:	218780 Click image for larger version.
    Current Stock
    1985 Honda 250SX
    2008 Honda XR650L
    MOTOVIKING
    PMA4X4
  3. #63
    Jun 2015
    Arizona
    69
    Quick video of the diff from the 250sx
    BAAAAAHHHHHH Its still good!
    Current Stock
    1985 Honda 250SX
    2008 Honda XR650L
    MOTOVIKING
    PMA4X4
  4. #64
    Jun 2015
    Arizona
    69
    Diff has been sent to FlyingW for a rebuild. Hoping to get the front end back together this week. Been busy with other stuff and have quickly acquired some other toys
    1985 ATC 70
    1983 ATC 185S
    1983 ATC 200E
    Going to try and flip them for some cash.
    Current Stock
    1985 Honda 250SX
    2008 Honda XR650L
    MOTOVIKING
    PMA4X4
  5. #65
    Apr 2012
    USA
    4,133
    Just a suggestion, might want to send off the rear axle to get sand blasted, acid dipped, then zinc plated. It is somewhat common for the rear axle to get pretty rusty and take out the splines for the ring gear, I have one that came like that. Make sure to seal the axle tubes up well when you re-assemble .
    I think I read members getting it done on sports 3 wheelers for around $70ish.
  6. #66
    Jun 2015
    Arizona
    69
    Not a bad idea. I have a friend that works at a shop that gets stuff zinc plated. I'll have to ask. The shaft is in relatively good condition better then the other one I have for sure.
    The tubes were petty clean but you can see where it leaked thru. The sister rear end I had looked like it sat in a swamp for 20yrs.
    Sent from my Nexus 5 using Tapatalk
    Current Stock
    1985 Honda 250SX
    2008 Honda XR650L
    MOTOVIKING
    PMA4X4
  7. #67
    Jun 2015
    Arizona
    69
    So much for using Hi-FLite (CEET) foams. wrong size or cut or whatever and they say no returns. We'll see how this goes down.
    Ok thumbnails are being stupid now.
    Current Stock
    1985 Honda 250SX
    2008 Honda XR650L
    MOTOVIKING
    PMA4X4
  8. #68
    Apr 2012
    USA
    4,133
    That seems a bit shotty for the company not to take responsibility if they have it listed for the wrong machine or they made a mistake. Have any idea what it actually fits? Maybe you can ebay it off and find another company that has the correct part. Seems it is a bit too far off to make it work of what I can see in the pics.
  9. #69
    Jun 2015
    Arizona
    69
    Just got off the phone with Roy at CEET. they did in fact send wrong one. but still no returns so they are shipping out another stock shaped foam. I told them since they didnt show or list the stock shaped foam I had already ordered another one from Saddleman and they said they will exchange but no return.
    Ugh, so now I will have a spare new foam and cover I have to sell.
    Current Stock
    1985 Honda 250SX
    2008 Honda XR650L
    MOTOVIKING
    PMA4X4
  10. #70
    BigRedGrizzly's Avatar
    BigRedGrizzly is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Jersey
    296
    Probably costs more to ship than it does to produce.
  11. #71
    Jun 2015
    Arizona
    69
    Quote Originally Posted by BigRedGrizzly View Post
    Nah, dont think so cause I can ship it back to them for $14 bucks fedex ground. Either way I'll get ti figured out.
    Current Stock
    1985 Honda 250SX
    2008 Honda XR650L
    MOTOVIKING
    PMA4X4
  12. #72
    Jun 2015
    Arizona
    69
    Next up found a shop recommended by my local MC parts store on stripping the gas tank I do have. There are no dents but a rust pin hole up top and no indication of rust below at all. $80 to strip and and then I can take it to my powder coat guy and have it finished for $50. So for $130 I have a new metal tank and will send the Clarke back. Which means i can use the 86 SX decal set I have!
    Current Stock
    1985 Honda 250SX
    2008 Honda XR650L
    MOTOVIKING
    PMA4X4
  13. #73
    Apr 2012
    USA
    4,133
    Glad you got something worked out with the seat foam supplier, maybe someone on here could use one and save a ton on ebay fees .
  14. #74
    Jun 2015
    Arizona
    69
    Now that I can save the tank I am going with the '86 color scheme.
    Current Stock
    1985 Honda 250SX
    2008 Honda XR650L
    MOTOVIKING
    PMA4X4
  15. #75
    Feb 2013
    Senoia, Ga
    635
