Results 1 to 7 of 7
Thread: 86 250r swingarm bearing collar length
    Apr 2014
    wisconsin
    146
    anybody know what the length of the collar tube in the swingarm is supposed to be? mine is pretty worn and beat up and id like to replace it.
    Oct 2006
    2,504
    PM bkm, I think you can get some delrin bushings to replace the bearings, collars and sleeves.
    Here is a set installed in my 85R swingarm.
    House Springs MO
    5,496
    Thank you Mr Clean. My delrin bushings are for sale here in the 3ww parts store.
    Sent from my SCH-I535 using Tapatalk
    Las Vegas, NV.
    2,531
    Quote Originally Posted by jrooster View Post
    2.525" or 64.2 mm.
    Jan 2013
    minnesota
    5,911
    well you have two pivot bushing collars and one axle bearing spacer/collar . . all are available new at the site below . . prices are in british pounds.
    the swing arm needle bearings are also available.
    http://www.cmsnl.com/honda-atc250r-1...1.html#results
    some of these pop up on ebay too on occasion.
    Apr 2014
    wisconsin
    146
    Sorry shoul have clarified. I need the length of the axle bearing collar. Thanks guys.
    Las Vegas, NV.
    2,531
    Disregard my measurements then, as they were for the collars, that ride inside the needle bearings, at the swingarm pivot point.
    Honda calls it a, "Distance collar", part #42621-HA2-670. Service Honda shows it as being in stock for 23.28 in US $'s. It's item #1 on the parts fiche, but you probably already figured that out.
    http://www.servicehonda.com/parts/lo...FE1AHA28F1801A
