Page 4 of 8 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 46 to 60 of 113
Thread: Built from scratch: 250R
  1. #46
    Aug 2015
    Germany, Bavaria
    98
    Update for today...
    The cones that came out from my excle spreadsheet were drawn in my CAD programm to get different measurements for the fitting of the final pipe which will be bent in different dimensions.
Name:	pipe straight.jpg
    That information was used to design the pipe around my trike. A small steel tube with some styrphor circles was bent around the frame to find a way through the trike with enough clearance:
    Sorry i dont have a picture with this dummy pipe on my trike...
ID:	220639Click image for larger version.
ID:	220640Click image for larger version.
    We improvised a 3d scanner with 3 rulers for X Y and Z axis and imported the form of the steel tube into the CAD by measuring 30 points.
    This will be the the base for the CAD model:
  2. #47
    Aug 2015
    Germany, Bavaria
    98
    Now some computer magic from me:
ID:	220643Click image for larger version.
ID:	220644Click image for larger version.
ID:	220645Click image for larger version.
  3. #48
    Aug 2015
    Germany, Bavaria
    98
    Finished CAD model:
ID:	220648Click image for larger version.
ID:	220649Click image for larger version.
ID:	220650Click image for larger version.
  4. #49
    Aug 2015
    Germany, Bavaria
    98
    Computermagic part 2:
    Draw off the cones fur
ID:	220652Click image for larger version.
ID:	220653Click image for larger version.
    That was done 32 times and all cones were printed for a test fit:
ID:	220655Click image for larger version.
ID:	220656Click image for larger version.
ID:	220657Click image for larger version.
ID:	220658Click image for larger version.
    The result was a catastrophy i am better with sheet metal than with paper
    Netxt try with stronger paper:
ID:	220661Click image for larger version.
ID:	220662Click image for larger version.
ID:	220663Click image for larger version.
ID:	220664Click image for larger version.
  5. #50
    Aug 2015
    Germany, Bavaria
    98
    The data was sent to my employer for the laser cutting and the waiting time was used to disasamble the trike for the final welding and the paintjob:
    Last picture of the naket trike without paint:
ID:	220666Click image for larger version.
ID:	220667Click image for larger version.
    Final welding job:
ID:	220669Click image for larger version.
ID:	220670Click image for larger version.
ID:	220671Click image for larger version.
  6. #51
    Aug 2015
    Germany, Bavaria
    98
    All the levers for brake gearshifter and so on were blacksmithed in my stove:
    For the next few steps this baby machined by Loizl (props to him at this point) will be used:
ID:	220673Click image for larger version.
    But that is another story i will post within the next days... thats all for today
  7. #52
    Surprise, AZ
    2,428
    ^ nice custom slip roll.
  8. #53
    Aug 2015
    Germany, Bavaria
    98
  9. #54
    Aug 2015
    Germany, Bavaria
    98
  10. #55
    Aug 2015
    Germany, Bavaria
    98
  11. #56
    Aug 2015
    Milford, PA
    Wow, what an awesome project! Nothing like building it yourself
    Sent from my SM-G900V using Tapatalk
  12. #57
    Surprise, AZ
    2,428
    Quote Originally Posted by sticker_sääp View Post
    Question to all the shock and suspension freaks: has anyone ever used a rearshock with a reservoir upside down?
    Gesendet von meinem C6603 mit Tapatalk
    If the shock is in good shape, doesn't leak, was bleed correctly and charged correctly you can run it in any position you want.
    What is the issue?
  13. #58
    C.J is offline Just Too Addicted Arm chair racerJust too addicted
    Central, Louisiana
    639
    The Suzuki quads use the shock "upside down" having the reservoir hose mounting at the "bottom" of the shock.
    Amazing build!!! I'm EXTREMELY envious of what you have to work with! "Oh I couldn't afford to just go out and buy an intake so I made one while I was sipping coffee and reading the newspaper one morning" lmao
    92 JP Outlaw hybrid (in progress)
    87 LT265R (not much left stock)
    too many bikes to count. too little time on hand.
  14. #59
    Aug 2015
    Germany, Bavaria
    98
    Ok, cause i got that statment from you two, i will go on with this setup and stop looking for a replacement shock.
  15. #60
    Aug 2015
    Germany, Bavaria
    98
    Quote Originally Posted by C.J View Post
    Thank you It does not hapen while i am sipping coffe. That whole level of the shown engineering/building/machining skills that created this trike is the result of a great team of the best mechanics, welders and so on that supports me. We have some kind of skill network that helps out each other.
