Results 1 to 12 of 12
Thread: 85-86 250r rear brake caliper upgrades?
    1,641
    Anybody ever upgrade rear brake caliper on 85-86 250R.For the cost of replacing or rebuilding the current one,looking at replacements.Haven't looked at 450 R yet.
    Nov 2014
    Chico,CA
    473
    Always used steel braided lines and soft brake pads on my 85 250R/200R/500R, are yours locking up to easily or just not enough brake power?
    House Springs MO
    5,496
    I swapped a 450r caliper on my old 86 trx, I wouldn't call it an upgrade, but it was a cheap alternative.
    Sent from my SCH-I535 using Tapatalk
    1,641
    New build.Braided brake lines are a defjnate.The rear caliper is in pieces curently and in rough condition.
    Nov 2010
    Oshawa, On, Canada
    2,123
    If its an 86 a front caliper off of a YZ125 will bolt on the rear of the 86R with a 16th or so of filing to one mounting hole. I have been running mine for 4 years like that
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Williamstown PA
    5,825
    If you have a custom mount made you can use a TRX450R or something off a YFZ. If not just rebuild it. Takes about 5 mins if that if ya have all the parts.
    honda4h's Avatar
    honda4h is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    ottawa ontario
    361
    Jason what year of YZ125 front caliper did you use. i'm in need a good alternative for the rear for my 1986 250r. thanks
    House Springs MO
    5,496
    Trx 450r requires nothing custom. All bolt on oem parts.
    Williamstown PA
    5,825
    problem solved...use a TRX450R one! Might be a little pricey compared to new $10 pad and a $20 rebuilt kit from bikerchic on ebay. You can always sell your working one on ebay and let everyone jack up the price so the 450R one is about free. I'd still pop out the cylinder and clean it up if the seals are decent.
    Jan 2008
    nc
    739
    will the caliper bolt onto the 250r brake stay or will a 450r stay be needed?
    Jul 2012
    Joplin, MO
    597
    I know a guy that did the swap, and he said to use the 450r hub and rotor, brake stay, caliper, and fade nut. He said you will need the 250r threaded sleeve because it is a little longer. He said it fits and works great.
    ky
    88
    I'm doing the yz swap now, a caliper from a 98-03 yz 125,250,400f will work I believe.
