Originally Posted by
ps2fixer
This for the write up! I have done a little research on this in the past with a little more technical details but less of the critical details that you cover such as the photos!
From what I remember, there is a calculation for surface area to be plated and amps for the "ideal" speed/time. I'd say an axle would take atleast 2, maybe 3 anodes hooked together to spread out the power source, and either run a larger power supply, or 2-3 of them and keeping the anodes not shorted together. A battery charger isn't required, anything that puts out power works great. Lots of people have used computer power supplies, but the process is slower. The old black box plugins for phones, routers, etc work too, you just need DC power. I don't remember if Voltage mattered or not, laptops and printers use 17-36v, so that might be a bit too high.
Someday I'll get into zinc plating, it seems simple enough and the results are generally great vs what you start with.
