Results 1 to 8 of 8
Thread: 450r swinger swap questions
    rustyhondas's Avatar
    rustyhondas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Missouri
    319
ID:	227300Will be using 250r shock and linkage with durablue link
    Can I use my Polly swingarm bushings from the 250 in the 450 swingarm ?is the O.D. Correct on them?
    I can shave them down if they are too wide I'm thinking
    Will be using the 250 bearing carrier . I understand I need to come up with two 1/8 shims for it , Do you recon I could just use two carrier snap rings stretched over the carrier on each side to shim it ?
    Thank you
    My steel swinger looks like shiet again and always wanted something better back there
    86 atc 250r
    85 atc 70
    84 atc 200s
    05 650 rincon
    06 400at rancher
    93 lt80
    02 kx65
    Jul 2012
    Joplin, MO
    597
    Where the bushings go on the outside, is made onto the 450r swing arm. The ID is the same and you can cut them off flush, but the gap will be too big for the R bushings.
    Sent from my KFFOWI using Tapatalk
    Nov 2006
    Missouri
    319
    Piles of parts coming in the mail now
    I see that you have to cut a little bit of the chain
    Slider away , , I run a 15t sprocket ,is that going to be a bigger problem ?
    Is a TMD slider a waste or a no go all together with a 15t
    They are pretty chunky
    86 atc 250r
    85 atc 70
    84 atc 200s
    05 650 rincon
    06 400at rancher
    93 lt80
    02 kx65
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by rustyhondas View Post
    As far as the bushings go, bkm should be able to make whatever you need if:
    1. He still is making the delrin bushings
    2. You can provide him with the proper measurements ID & OD
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    House Springs MO
    5,496
    I'm still making the vintage bushings, 200x, 2nd & 3rd gen 250r, but not taking on any new projects unless someone supplies all measurements they want. I've got a 450r swingarm here, but don't like it's design to use Delrin bushings. I think it's best suited for modified oem components.
    Sent from my SCH-I535 using Tapatalk
    Nov 2006
    Missouri
    319
    I got the OEM 450 and aftermarket 250 plastic delrin
    Pivot bushing and a makita I'll make something happen there
    I guess I will see if that big 15t sprocket will squeeze in there,if it's so tight you have to cut the slider ,
    It makes me wonder
    I bought two new brake caliper bracket snap rings,to use for carrier bearing spacers
    To take up the 1/8 gaps I read about , kind of ghetto
    But there shiny and strong , F-it
    86 atc 250r
    85 atc 70
    84 atc 200s
    05 650 rincon
    06 400at rancher
    93 lt80
    02 kx65
    Jul 2012
    Joplin, MO
    597
    I have a 15 on mine. I had to cut quite a bit off the slider but it works fine.
    Nov 2006
    Missouri
    319
    Excellent news
    86 atc 250r
    85 atc 70
    84 atc 200s
    05 650 rincon
    06 400at rancher
    93 lt80
    02 kx65
