Thread: XR200R/200x 6 speed swap experience
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    After searching around for a bit I couldn't find much for people posting a finished ride report after swapping the xr 6 speed bottom end into a 1st gen 200x. I'm aware of the steps needed to perform the swap, I'm looking for opinions of anyone that has successfully done it and have ride time on it.
    I was given an 82 xr200r with a stuck motor and general abused condition. I yanked the motor and took the top end off, which then the bottom end turns smoothly and goes through all the gears. The piston and cylinder weren't too bad, just stuck from sitting for a long time. The cam is shot, exhaust lobe was been rounded fairly well.
    I'm considering putting my 200x top end on the xr200r bottom end, but am hesitant as I haven't really read much other than discussing how to do it. Would the 200x have enough power to really benefit from the 6th gear? I don't take my 200x for all out top speed sprints and I believe the top speed gain is only around 5 mph (thought I read that somewhere, correct me if I'm wrong) anyways?
    If anyone has performed the swap and has ride time I would like to hear your opinions and thoughts.
    Thanks!
    And of course a picture of the poor thing. Upside down and too lazy to figure out how to flip it...
    It has a plastic gas tank in good shape, minor cosmetic flaws on the exterior. Not sure if that's oem or not. If anyone wants parts off it, let me know.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    London, Ontario, Canada
    1,059
    I did the trans swap into a 200X motor
    http://www.3wheelerworld.com/showthr...her-full-build
    Gear ratios for 123 are equal from one to the other, 6th gear is slightly faster on the XR than 5th in the X and really the difference is slightly closer ratios from 3rd up. I ran on 20" tires so I'm not sure what kind of top speed change happened. I never really got to ride the 5 spd as the kicker gears were gone so I don't have any side by side comparison. The only thing I can say is the close ratios of the 6 spd and 20" tires only made a great trail bike even better.
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
    Jan 2014
    Massachusetts USA
    782
    I almost did one last year, still have all the needed parts. I chose not to for all the reasons stated above, and I don't regret it. I also found out through research that there are two different six-speed XR transmissions. The later one (not sure of the cutoff year) has identical first through fifth ratios as the 200X. The early six speed, which turned out to be the donor I had, was the same in second through fifth, but had a really low first, which I didn't like.
    After riding my 200X with the stock trans in tight trails, open fields, and semi-fast cart paths, I still have no regrets. If I rode a lot of wide open area where top speed could be higher, maybe I'd like the sixth gear. The choice is up to you, just depends how you want to ride it. Lastly, don't forget that if you want to keep the 200X forward kicker, you'll be splitting that XR case anyways to swap the kickstart spindle (as well as your 200X if you don't have a donor spindle).
    1985 Tri-Z 250
    1985 ATC250R
    1,059
    I stand corrected, Here are the transmission ratios for both. It seems gears are identical with a lower 6th gear added to the XR. I can't remember where I found the other info on Ratios(could have possibly been XR200R info)
    XR 200 gear ratio's
    Primary reduction
    3.333: 1
    1st gear 2.769: 1
    2nd 1.941: 1
    3rd 1.450: 1
    4th 1.130: 1
    5th 0.923: 1
    6th 0.785: 1
    1983 - 85 ATC 200 X gear ratio's
    Primary reduction
    3.333: 1
    1st 2.769: 1
    2nd 1.941: 1
    3rd 1.450: 1
    4th 0.130: 1
    5th 0.923: 1
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    My Wife's Ride
    My Kids Ride
    1979atc's Avatar
    1979atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2015
    NW Ohio
    213
    I have an 1988 xr 200 with the 200x 5 speed bottom end.
    1979 Atc 110 helm and son
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    1988 XR 200 bored 40 over,
    Atc 200x bottom end.
    Jan 2014
    Massachusetts USA
    782
    Like I've already mentioned, the XL200R was a five speed, and as it turns out, the XL185S has the same ratio five speed transmission.
    What I haven't seen is mention of the XL185S and XL200S five speed.
    The XL transmission has the same first gear ratio as the XR and ATC transmissions, but it's all different from there and fifth gear is actually 1% taller than the xr200's sixth. What that means is it should work really well with a more powerful engine that can handle the larger gear jumps and still be stronger than the six speed, while covering the overall ratios of the six speed.
    I have an XL185 engine in my XR185. I can tell from experience that the wide ratio XL trans sucks in tight woods.
    1985 Tri-Z 250
    1985 ATC250R
    Jan 2014
    Massachusetts USA
    782
    What final gearing are you using?
    14/50. My gripe is that sometimes first is too low, but second is too high. The wide ratio trans just leaves me with a "hole" that is exacerbated by my choice of sprockets.
    Regarding my 200X, I would never need the sixth gear that the XR200 offers, but I could probably live with the wide ratio XL trans. That actually might be a winner in the trike, as the small tires let it accelerate fairly well, and the ratios seem pretty close in the 200X.
    Now, if we really want to derail a thread with lousy transmissions that will fit in Honda 200 engines, how about the super-close ratio CB125 trans? That ought to really suck big time!
    1985 Tri-Z 250
    1985 ATC250R
