So? 200X
Why is the sprocket mounted on rubber dampers from 83 to 85 ATC200X??
Is it the swingarm bolt, that the knucklehead can't line up marks right solution??
Why do 2 stroke pipes have springs? And a thumper has a solid mounted exhaust?
My thumpers vibrate?
AND, I CHALLENGE THE WORLD!!!!
What on Earth is the tab with the hole drilled in it welded on the 86 200X and 350X swingarm ( maybe the other years as well...), left side, maybe 6"s from the axle?
Nothing mounts there, I've never read anything??......
