Results 1 to 15 of 17
Thread: So? 200X
    So? 200X
    Why is the sprocket mounted on rubber dampers from 83 to 85 ATC200X??
    Is it the swingarm bolt, that the knucklehead can't line up marks right solution??
    Why do 2 stroke pipes have springs? And a thumper has a solid mounted exhaust?
    My thumpers vibrate?
    AND, I CHALLENGE THE WORLD!!!!
    What on Earth is the tab with the hole drilled in it welded on the 86 200X and 350X swingarm ( maybe the other years as well...), left side, maybe 6"s from the axle?
    Nothing mounts there, I've never read anything??......
    House Springs MO
    5,496
    How exactly is a rainbow made? How exactly does the sun set? How exactly does the posi-traction rear end on a Plymouth work? It just does!
    Surprise, AZ
    2,428
    It comes down to play bike or trike and high performance bike or trike.
    The rubber dampers cut down on vibration and also wear on the transmission.
    2 strokes use springs to cut down on vibration, spider cracks in the pipe or breakage. High performance 4 strokes use springs as well.
    On a side note it is much easier & cheaper to remove springs with a spring puller then buying a mill to remove your broken studs.
    I heard long ago the tab was use in Europe to mount a chain cover, I don't know if this was stock or a Hondaline option, OR if it is even true. (It used that tab, the 2 front buffer bolts 2 of the bottom skid plate bolts) Chain covers are fairly popular in Europe.
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    Quote Originally Posted by onformula1 View Post
    Way to take the fun right out of this with facts n stuff.
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    Surprise, AZ
    2,428
    Quote Originally Posted by arlaunch View Post
    Ouch, keep in mind many a play trike has been turned into a high performance trike.
    Maryland
    3,077
    Oldschool idea decendent from motorcycles that the rear drive sprocket being "cushioned" saves wear on the drive train
    No not a good solution, hence why the redesign. (and if I misunderstood I don't think the rubber dampeners have anything to do with it)
    You're thumpers are still counterbalanced and most 2 strokes are not. Many newer thumper aftermarket pipes are attached with spring because vibration breaks them. The two brothers I have on my 450 is an example, solid mounted first design, went to springs in a recall cause the head pipe was cracking and breaking off at the cylinder mount.
    This is to help steering in deep water crossings, it keeps the bike going straight like a sharks fin.
    That'll be four nickles please.
    Answer Pricing
    Dumb Looks $FREE
    Answers $.05
    Good Answers $.10
    Correct Answers $100
    Scootertrash's Avatar
    In the sticks
    4,638
    Why do we park on a driveway and drive on a parkway?
    Oct 2013
    Wherever I May Roam
    3,757
    Lots of bikes have cushioned drive sprockets, as of1 said, to protect the trans from having to withstand constant impacts. All of the atc200 and 200s series have cush drive sprockets. Many enduros and street bikes utilize cushioned drive in several different configurations.
    As a side note, I just modified a cl175 sprocket to convert this to a solid mount sprocket.
    Oct 2013
    Wherever I May Roam
    3,757
    Oh I almost forgot... Why is the alphabet in any particular order?
    Fear of long words: Hippopotomonstrosesquippedaliophobia
    WHY?!
    Williamstown PA
    5,825
    It was just something they tried. Who eles tried it? Sure it was cool, Sure it worked but so does todays non crush drive.
    Oct 2013
    Wherever I May Roam
    3,757
    It wasn't just "something they tried" it was and still is widely used in the powersports industry.
    Feb 2003
    Australia
    927
    It is incredible the way people die in alphabetical order. Have a look at the funeral announcements in the newspaper.
    Soutwestern PA
    2,040
    You have two options for that. Either mount a very short whip flag or a teeny tiny ball hitch.
    Aug 2014
    South Louisiana
    1,915
    I didn't want to be the first person to ask what that was. Glad I'm not the only one without a clue.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Mar 2008
    Hazleton, PA
    92
    Nothing mounts there, I've never read anything??......[/QUOTE]
    I've thought about that also only conclusion I could come to in my head is it was maybe used in the factory to hang either to paint or just move then around on a assembly line
