True that like many things, chainsaw world has it's cheap throw-away models, and EVERY brand across the board has their cheap models. Often they are classified as "homeowner" models...
Anywho, you say you replaced the carb. Are you 100% certain it is the correct carb? And why did you replace it?? Saw carb issues usually can be easily remedied with a good cleaning and a kit. Metering lever height is crucial and if too high the saw will flood out bad pretty fast. You say it seems like it is flooding, is the plug soaked after attempting to start it?? I only know of a couple of models of saws that have completely non-adjustable jets other than the new Autotune and M-tronic models offered by Husky and Stihl respectively. All others have some level of adjustment, but are limited with little caps mandated by the EPA.
Also, what is the condition of the fuel line, fuel filter, tank vent and primer lines?? A problem with these is often blamed on an innocent carb.
Need a little more info from ya.
Most saws can be tuned up and repaired, even the cheap models. The concern is not putting more $$$ into it than it is worth.
Or you could buy a Husky 372 and an unlimited coil and send it to me for porting! LOL! I've been really into saws lately.
