Page 2 of 16 FirstFirst 1 2 3 4 12 ... LastLast
Results 16 to 30 of 237
Thread: 350X 400EX Transplant Build!
    devore,ca
    1,054
    Quote Originally Posted by Matt85'350x View Post
    The advantages for me are as follows:
    -Electric start
    -Reverse
    -Lighter engine (don't know the exact numbers but I do believe it's lighter)
    -More aftermarket support/parts availability
    Other than that I don't know what to tell ya. It's something that I've wanted to do for a while. The overall idea is to end up with a more modernized 350x. A 450 hybrid would be cool but a bit out of reach for me plus I really like the 350x so a modernized version of it really appeals to me.
    That's a good enough list to justify it. For me it was the e start I was after, the oil tank was the killer of the project though. I've seen a few ex conversions (pictures) and the oil tanks seem to be the problem . Maybe under the seat somewhere or along the side under the rear fenders would work, but all the ones I've seen are mounted out front like the quad and look hideous, and vulnerable.
    So I elected to go the 450 hybrid rout.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Aug 2007
    Montana
    857
    WHAT AGREAT UPGRADE............that push button start and reverse are a great way to fly ! Great job!! Ol Deuce
    DO the Best With What you got !
    My Feed back :cool
    Freedom Township, MI
    642
    Quote Originally Posted by BOB MARLIN View Post
    You read my mind! To me the solution to the oil tank is in the motorcycle world. There are hundreds of ready-made tanks made for motorcycles that could be used for this project. No reason to make a custom tank. Right now I'm leaning toward having the tank hang off the side of the rear of the frame. If I did that I'd get something like this: http://www.ebay.com/itm/Basic-Round-...H8oCFQ&vxp=mtr
    Or this: http://www.ebay.com/itm/CHOPPER-BOBB...Bq0PtA&vxp=mtr
    If I decide that it needs to be between the carb and swingarm, this might work (gotta check the measurements). I measured around 3 inches being available but the mounting plugs might get in the way. http://www.ebay.com/itm/3-in-Custom-...9W112x&vxp=mtr
    I'm leaning towards hanging the tank off the side because I'd gain some oil capacity which I believe will help with cooling. Besides that I see no reason to hide the mechanical things, I think it'd look good. I used to love Indian Larry's builds because he would always showcase the mechanical parts of the bike-one time he had the oil filter hanging right out the side of the bike! I'm no Indian Larry, but I don't see anything wrong with a tank hanging off the side of the trike.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    2003 Polaris Predator 500
    1988 Yamaha Warrior
    2003 Polaris Predator 90
    Previous Trikes:
    84 Honda 110 (parts)
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    KX 80 Trike conversion
    Gone and missed:
    642
    So far this the scariest part of the build. In order to mount the rear of the engine, I actually had to drill the cases. This mounting hole does not go all the way through. No idea why, but it doesn't. When I looked at the case halves on Ebay, there's nothing there to put at risk, it's just not all the way through. After I realized this I went back and re-read "Top Notch 350x" build and he mentioned that you have to drill the hole out. So I held my breath, said a prayer, and drilled it out:
    It drilled really easy. Didn't see any oil come out, so I think I'm good!
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    1988 Yamaha Warrior
    Previous Trikes:
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    Gone and missed:
    Blossvale NY
    4,563
    This is fantastic!! Nice work thus far Sir!
    The oil tank: ever give any thought to running some sort of pod filter that would allow room for the tank where the air box is?? Myself I would be a little concerned mounting the tank outside the frame under the rear fender. Seems like it could sustain some damage from flying debris and whatnot there so close to the rear wheel with nothing to protect it. Particularly in the cases where a descent sized tree branch gets tossed by the rear wheel. As much as those hurt to get hit by, I would suspect it could damage an oil line
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Lewiston, N.Y.
    1,479
    Sorry for the ignorance but why do you need an oil tank? Do you not put oil in the crankcase?
    642
    The same thought crossed my mind but I didn't think of a pod filter. Definitely an idea but would prevent me from running in the mud right?
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    1988 Yamaha Warrior
    Previous Trikes:
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    Gone and missed:
    642
    Quote Originally Posted by userj8670 View Post
    The 400ex has an external oil tank. The oil is pumped into the engine. Not the only engine to do this.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    1988 Yamaha Warrior
    Previous Trikes:
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    Gone and missed:
    Blossvale NY
    4,563
    It's true that running a pod does require a bit more care in wet and muddy situations, but I wouldn't think you would have to avoid the mud 100%. I would just be a little more careful, avoid hitting deep water holes and getting it buried up to the seat. An Outerwears can help a bit in this regard.
    If you look for mud to play in alot, then a pod probably won't suit you.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Oct 2013
    Wherever I May Roam
    3,757
    If I were building a trike with a dry sump motor, I'd thoroughly clean and close up the backbone and the downtube of the frame and use it for the tank.
    House Springs MO
    5,496
    You beat me to it as I was thinking the same thing. The XR400 is basically the same engine and uses the frame as the oil tank.
    devore,ca
    1,054
    Now you guys are seeing why I kept talking myself out of the EX conversion and went strait to the 450.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    642
    I knew what I was getting into when I started this. Not too interested in using the frame. Don't know that it could hold enough oil. This isn't an impossible issue-it will be overcome.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    1988 Yamaha Warrior
    Previous Trikes:
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    Gone and missed:
    642
    I never go looking for mud but it seems to find me. When this is done I'll probably just not ride if it's muddy. I've got a lot planned for this build, it's not just the engine. Frame will end up getting sent to HRE to get gusseted and fitted for one of their swing arms. I've got some low pros for the rear and new plastics everywhere else. Also got an aussieduner white light for the front.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    1988 Yamaha Warrior
    Previous Trikes:
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    Gone and missed:
  15. #30
    Oct 2013
    Wherever I May Roam
    3,757
    It will hold plenty of oil. Why aren't you interested in using the frame? Its the obvious answer. In my opinion. Aren't you going to run a cooler?
