Results 1 to 15 of 27
Thread: Do the front forks on a ATC 250 R, fit a 200X?
    Leevvii's Avatar
    Leevvii is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2016
    Australia
    216
    Do the front forks on a ATC 250 R, fit a 200X? Any bits transpose to the 200 X? Also, do any other motors bolt straight into a 250R frame?
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    BTW, i mean '84 200X, and '83 250R, sorry to be too broad, but any info will help
    House Springs MO
    5,496
    I believe the 83-84 250r triples and forks will swap onto a first gen 200x, but they are longer and raise the front end up a few inches. Look up shortline10's threads on here. I think he has this setup on his race bike with a plus 2 swinger.
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    thanks mate
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    Brilliant info in this thread
    http://www.3wheelerworld.com/showthr...50r+parts+swap
    , front end swap on my 200X '84, forks from a 250R '83 frame i have [im hoping they fit???].
    i keep you posted.
    Oct 2014
    tn
    110
    Yes you can, I have a set of 84r triples I had bored to accept the 200x steering stem.
    the only time I will be easy is when I'm killed by death
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    Thanks, hopefully all goes well
    n
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    This pic is the '83 250R forks, I assume the misalignment [??20deg] between the forks themselves and the headstock shaft, is intentional .....yes?
    n
    Jul 2011
    Colorado
    141
    Yes. Its normal. Also on the 85/86Rs.
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    Thanks, thats excellent news. Should have the forks on in next week of two, I always thought the front of mine needed raising a tad, cant wait. I assume the frame can handle [structuraly] the slight increase in angle with the R forks in place? That would affect the C O Grav also, not that i care, just sayin. The bearings look OK, hopefully they will clean up. Id think those bearings would wear slowly [light load, as bearings go], and it would be rust or grit that would be the killer, mine look pretty clean, so im hoping they are useable, fingers crossed. I have 1 broken bolt in the L axle holder cover, hopefullt an easyout will fix that, otherwise, its all looking good for 200"R"X
    A question, two actually.
    and 83 R shock...
    Your refering to the R's REAR shock, ....yes? Do they fit the X frame and swingarm? I have 2 laying around .......[rubs hands together in anticipation!] Also have the R swingarm, could i be so lucky as to just slide them in?
    Q2:- In your photos [oldskool], 1st and 2nd pics, what is the motor in those 2 X's ?
    n
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    Also, i read in the 200X shop manual, the shock fluid overhaul procedure, i assume the regassing must be done professionally? Any aussie NSW folk know where to get this done?
    n
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    Nice job mate, looks pretty schmick!! In not racing mine, so im keeping the mods to a minimum, but im a chronic tinkler! Sorry to drive you mad with questions! LOL
    That swingarm in the pics, is that the X arm ?
    them bore it to accept stock 200x stem because stock 200x stem is larger diameter
    This is required or optional? I ask, as i was intending to use the R's bearings, or is that not possible?
    HRE rear dog bone mount why, because it keep rake the trail the name when going with longer suspension
    Sorry mate, i dont get what you mean on the "rake ......" bit. did you mean "Rake angle the same"?
    I brought an old 250R '83 [on VIN], came with most things just no motor [spewin!!], also 2 rear shocks, i cant garauntee they are '83, is there any unique markings on the "83 rear Shocky's ?
    n
    NEPA
    7,051
    We need more Aussies around here,,,just saying....,,Rake and trail,it is what makes a 3 wheeler go round and round. Google it and fill your brain lol. It all works out perfectly on this particular swap though,unless you are gonna be racing it super hard, then you will want a pretty aggressive front tire. I highly doubt you will even notice. It's a great swap. Let us know how you like it when done.
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    I know a thing or two about 200x's
    Yeh, i noticed that LOL, and appreciate your help, keep it coming!
    you could of had it done by now
    settle down there old mate, Im Australian, we do things at a more liesurely pace. No rush mate! LOL I got plenty big ideas, but dont have easy access to machining equipment, which slows things down a little also.
    I read a bit about the rake and trail, makes a bit more sense to me now, thanks for the link atc007.
    n
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    On my swingarm, one of the needle bearings is stuffed, some pitting on the large spacer sleeve [minor'ish], though all else is OK, so, is it better to buy just the bearings [Or buy a toyo equivalent maybe], or the complete kits?
    I know about and would prefer the derlin replacement sleeves, but i cannot source them anywhere that i know of.
    n
