Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 76
Thread: MPDano New Project: 1985 ATC 250SX **DONE**
    Mar 2007
    Hampshire U.K.
    536
    All this in under a month? I salute you sir!
    ATC 70, ATC 250es, 1/32 ATC 250R
    1 person in 10 understands binary, the other one doesn't.
    Trikefest UK '08 survivor!
    MPDano's Avatar
    MPDano is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2014
    Quote Originally Posted by Hair Bear Bunch View Post
    Thanks sir. This is a real fun project.
    MPDano's Avatar
    Sep 2014
    Mounted the front tire. Put a patch repair on it first, nice having a pool to check for leaks, lol. Put the wheel back on, which is a bear to line up and not without scratching my newly painted forks up too. Brakes work great, now to source the brake handle and cable. Painted some tank sealer on the gas gap so it will never rust. Installed a new gas cap seal too. Hooked up a new key switch so I don't have to jump wires now. Got a 2nd hand OEM starter switch coming so I can then hook up the choke and rear brake cables.
ID:	236965Click image for larger version.
ID:	236966Click image for larger version.
ID:	236967Click image for larger version.
ID:	236968Click image for larger version.
ID:	236969Click image for larger version.
ID:	236970Click image for larger version.
    Dec 2012
    812
    Did you install a new rear drum seal? Couldn't see one in the pic. Also let me know if you're still looking for a front brake lever. I have an extra one which is new - I don't need it anymore.
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by Big G View Post
    Didn't know there was a drum seal, all I saw was a large metal clip in there. I do desert riding so not too worried about moisture. Good to know tho. Oh wait, you said rear. I never opened the drum up, the brakes work so didn't feel the need to.
    Yupper, still looking for parts and they are in my ebay shopping cart, but funds come in slow, lol. Do you have the full right front brake perch/handle? If so, how much do you want for it shipped to 92021?
    Thanks,
    Leo
    Dec 2012
    812
    Ah dang...just the lever, no perch
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    MPDano's Avatar
    Sep 2014
    Bummer, yeah all front brake including the cable and bottom loom holder missing on my ATC. Seems like they started to part out at some point.
    MPDano's Avatar
    Sep 2014
    Finally got a working starter switch. Attached a new choke cable and she works like a charm. Found a large nut and ground off the threads and installed on the front axle to fix my centering issue. It is a little bit too wide but at least i know to get a couple large washers and this will fix it. Also, got an inline fuel filter installed. Will probably not use the in tank filter as it probably wont fit anyways with the tank seal lining. At least this way, I can replace filters without draining the tank.
ID:	237022Click image for larger version.
ID:	237023Click image for larger version.
ID:	237024Click image for larger version.
ID:	237025Click image for larger version.
ID:	237026Click image for larger version.
    Dec 2012
    812
    Glad to see you got the front wheel centering issue resolved, but from looking at pic #4, it seems like the tab from the front shock is just barely catching the slot in the drum due to the extra spacing now?
    Also, where did you get the new switch?
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    MPDano's Avatar
    Sep 2014
    Yes, this is why I am going to washers versus that large nut. This will get more of the slot in. Switch came from eBay. Got it for $28 with a broken choke lever, swapped with my good choke lever, done.
    MPDano's Avatar
    Sep 2014
    Mounted the new kicks on the rear wheels. Yes, the left wheel is 3/4" wider and is aluminum, right is steel. I'll sort that out at a later date. Installed the new rear brake cable/adjuster, reverse cable and new petcock.
    OMG! Do these 250SX 4 strokes have torque. Popping a wheelie without effort was awesome. Was itching to do this test run, especially to see if the reverse worked. And yup, works great.
ID:	237258Click image for larger version.
ID:	237257Click image for larger version.
ID:	237256Click image for larger version.
ID:	237255Click image for larger version.
ID:	237254Click image for larger version.
ID:	237253Click image for larger version.
ID:	237252Click image for larger version.
ID:	237251Click image for larger version.
ID:	237250Click image for larger version.
ID:	237249Click image for larger version.
    Dec 2012
    812
    Where'd ya get your petcock from? The aftermarket one I got for my SX was from Dr. ATV, and it sticks out past the side of the tank when threaded on, which I find looks kinda odd. Yours appears to be almost dead on to OEM, unless it's just the angle of the picture.
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    MPDano's Avatar
    Sep 2014
    Nope, it's pretty flush. Lever slightly hits the tank when putting on reserve. It was a cheepie chinese one off ebay. Got it for $6.49 shipped.
    May 2016
    OH Canada
    1,102
    Most people would have torched what you had at the beginning. GREAT save. Props to you.
  15. #30
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by Rob Canadian View Post
    Ha ha, yeah. I love a good challenge though. Plus, I get to learn on these as well. Always a fun process.
