Thread: 85' 250R Compression Questions
    Dec 2012
    Hello all you R experts,
    I have been adding upgrades to R and would like some input. I just installed a cool head after checking the squish both before and after installation. The squish is above .058. I think the cool head that I got is older because it dose not have o-ring grooves machined into the head. I am running a CR head gasket with a 22cc dome. I checked compression after installation. The gauge was at 200 psi. My engine builder recommends that I run 110 octane race fuel. What compression have you seen with a stock head using a CR head gasket? What is the highest 250r compression that you have seen?
    Thanks.
    Slidell, LA
    4,738
    IMO that's a pretty tight squish. Stock is around .090 at ~175-185 lbs of static compression. The tightest I have run is a .050 with static at 221 and I was running VP 110. You are definitely on the borderline. I would perform a UCCR to be 100% sure you can get away with pump gas
    Or
    Just play it safe and run 108.
    efhondakid's Avatar
    efhondakid is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2015
    Canton Ohio
    203
    CR HG? Haven't heard of that how much thinner is it and what year CR?
    2 in the back, 1 in the front.
    House Springs MO
    5,496
    Quote Originally Posted by efhondakid View Post
    I always used the 1989 cr250 head gasket. I think 88-91 cr250 uses the same gasket, but I know for sure 89 always worked.
    Snohomish, Wa
    1,028
    My 86 TRX 250r has a CR head gasket and my compression is at 200 psi. I am running 110 octane.
    85 ATC 250r -Under Construction
    86 TRX250r
    05 KFX400
    02 400EX
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    http://www.macdizzy.com/compress.htm
    Here is a link to some information regarding compression ratio vs. octane.
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
