Results 1 to 13 of 13
Thread: '87 250SX rear shock replacement
    Jan 2016
    Little Rock, Ar
    83
ID:	239815Click image for larger version.
ID:	239816Click image for larger version.
    I've been looking for a thread on here that would solve the problem of replacing the rear shock on a SX with something upgraded from the original. I found a thread that had a vague suggestion with added parts to make it work.
    I replaced the rear shock with a '93-'00 TRX300 rear shock and it needed no mods. Bolted right up with the original hardware and no spacers or dowels. I hope this helps anyone who was thinking of upgrading or replacing.
    '87 ATC 250SX
    '86 ATC 350X
    A bunch of stuff-n-stuff
    Mar 2003
    Australia
    1,919
    How does it compare with the original? Maybe feels better because it's newer?
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Jan 2016
    Little Rock, Ar
    83
    Quote Originally Posted by atcmatt View Post
    Matt
    At its current setting, this feels like a new SX shock should feel. It's at a mild setting and the good thing is that this shock has a rebound adjustment and plenty of compression left, unlike the original. I'm 220 lbs, so the original shock in the best condition is at its limit. I'll have to experiment with stronger settings to see if it offsets the front. I just replaced the fork seals and oil so they're at peak. Of course, the SX isn't a track bike so I'm not looking to shave off seconds on the backyard trails. As long as the tires stay off the fenders, I'm happy.
    '87 ATC 250SX
    '86 ATC 350X
    Austin, Massachusetts
    1,591
    what'd that run ya, if i may be so bold?
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    MPDano's Avatar
    MPDano is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2014
    Great mod find> I see some on eBay for $42.98 shipped.
    http://www.ebay.com/itm/Progressive-...VVjEPx&vxp=mtr
    MPDano's Avatar
    Sep 2014
    Mar 2003
    Australia
    1,919
    Wow sounds like a good upgrade, guess it would work perfectly on a 250es also? Think they have identical rear ends.
    Jan 2016
    Little Rock, Ar
    83
    Quote Originally Posted by MPDano View Post
    This one looks incorrect. I don't know if being for a 4x4 is the difference
    '87 ATC 250SX
    '86 ATC 350X
    Mike can you list the exact part number for the correct Bronco shock?
    Jan 2016
    Little Rock, Ar
    83
    This is the exact shock that I ordered. The only part number that I found is SU1102. The ebay ad also says that it will NOT fit the 300EX. I guess I just stumbled on an exact fit shock.
    http://www.ebay.com/itm/272453608826
    '87 ATC 250SX
    '86 ATC 350X
    MPDano's Avatar
    Sep 2014
    Quote Originally Posted by Helopilots View Post
    Good catch.
    Feb 2017
    MO
    50
    Awesome! Thanks man. I just ordered this one... I hope it works lol
    http://rover.ebay.com/rover/1/711-53...VVjEPx&vxp=mtr
    1984 ATC 70
    1985 ATC 250sx sold
    1986 Yamaha 225 DRSsold
    Feb 2017
    MO
    50
    It works like a charm. Had to trim the top metal bushing but that was it. Nice find!
    1984 ATC 70
    1985 ATC 250sx sold
