Page 71 of 313 FirstFirst ... 21 61 69 70 71 72 73 81 121 171 ... LastLast
Results 1,051 to 1,065 of 4682
  1. #1051
    Aug 2016
    East of Worcester ma
    1,358
    I read a lot of swineheart's posts back when he was making the 350X headlight shells, at least I think that was him. That's what piqued my interest.
    What's the proper term for making these molds, and the name of the material you use for the parts? I'm drawing a blank....
    Proper term i guess is mold making/casting will get you all the vids/info you need.
    Theres platnum cure silicone --costs more
    Or tin cure silicone but the molds dont last as long as platnum
    But certain things need the correct silicone to mold well
    If u need a quick list to experiment with try these: go to "smooth on" site
    Get tincure moldmax 30 -- for mold rubber material
    Get smoothcast 65d urethane -- for plastic finished piece
    then FOLLOW the directions!
    Your inside finished piece will be hard plastic kinda like a white (unless u add color) soda bottle cap
    Pick up plastilene clay from a craft store to help with molding and wont react bad w/silicone
    I've been using azek the plastic wood/boards for mold boxes (scraps from work)
    Then there is also colors you can add or a uv protectant additive even glow in the dark additives
    Then theres the mold release spray too
    Many different types of materials are out there but starting with these two products will get u going.
    Dont forget gram scale.
    Lots of paper towels+plastic cups+stir sticks
    If u want to mold a rubber piece well thats different. a clear lense (like tailight) is a different material also and the Tailight would be a translutient(sp) color not solid.
    Lots of info out there just dig around for it,
    Good luck i hope u try it/ just remember that i'm just a recent beginner also, but learning.
    Shep
  2. #1052
    May 2015
    San Diego, CA
    1,797
    making progress on the tank........very slowly but safely as well
    It still has some stubborn spots and hard to access spots as well
  3. #1053
    Mexico
    9,018
    Gotta love those plastic tanks.
  4. #1054
    Mexico
    9,018
    Today i`m dippin my fingas in my butt crack ..........and sniffing what the glam masterson has cookin ........think i`m gonna hurl
    Do you call your arse O.J.? Cuz when the fist starts to fit you’d better quit.
  5. #1055
    Apr 2002
    s.w. michigan
    6,498
  6. #1056
    Scootertrash's Avatar
    In the sticks
    4,638
    Thank You Mr. Swinehart!
  7. #1057
    In the sticks
    4,638
    If it's gonna fit, he must first take a sh!t
  8. #1058
    House Springs MO
    5,494
    What started out as a simple transmission swap ended up being crank bearings and all new seals along with the 98 transmission. I also made up a set of sleeves out of 2.5" solid bar stock to adapt the Showa 49mm conventional forks. I just need to get them to my buddy's mill for the pinch slits.
    Sent from my SM-G900V using Tapatalk
  9. #1059
    In the sticks
    4,638
    Maybe El can get you a good deal on a Harbor Freight grinder
  10. #1060
    In the sticks
    4,638
    Jack and glamy went up the hill
    Both with a buck and a quarter
    glamy came down with 250! Whoa!
  11. #1061
    May 2015
    San Diego, CA
    1,797
    That's good that the bearings, etc got done.
    Anytime I split a case.....unless it's in newer shape I always have new bearings pressed in by a shop
  12. #1062
    Mexico
    9,018
    If you must acquit............you can eat those little balls of sh!t !..............ha ........ha ha ........i made a funny too ! !!
    What did the constipated mathematician do?
    Worked it out with a pencil
  13. #1063
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    That's one way to budge it.
  14. #1064
    In the sticks
    4,638
    Thanks, but I'll pass. I would never take holiday snacks from the mouth of a struggling retiree.
  15. #1065
    In the sticks
    4,638
    I ate four cans of alphabet soup yesterday.
    Then I had the biggest vowel movement ever.
    What did the turd say to the fart?
    You blow me away
