Pivots like a tri-z, which IMO is not a bad set up. The round house carrier looks much better, and can be adjusted well, but I am a fan of the swinger style as well. Glam is right, there are heaps and heaps of banshee axles and carriers about.
I'm not sure if the banshee carrier can be adjusted, like the tecate swinger style. But if it works the same way, the tecate carrier it was the easiest chain adjuster to adjust known to man. The way to make it so is as follows: Remove the two fine threaded adjusters and throw them over your shoulder. When it comes time to adjust your chain, slightly loosen the pivot bolts, (I think there may be a lock bolt as well but I can't remember) and loosen the main clamp bolts, then roll the trike forward at walking pace, then hit the foot brake. This forces the carrier rearwards. Once stopped, lock off the clamp bolts, and the pivot bolts. If you master this technique the chain comes up at the right tension, every time. Loved that carrier.
If you must have a round house carrier, don't think you could go wrong with the modern yfz450, or raptor components. Those carriers are round style like the 250r carriers, but they have made tons and tons of yfz quads over the years, and they are still for sale. Unlike most other manufacturers quads.
Sent from my iPad using Tapatalk
My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
