81-84 atc250r fronts are the same too. It's crazy easy to rebuild calipers long as you got some spare bolts and air compressor and wd40.
I did the cr 80 caliper replacement works better IMO
the only time I will be easy is when I'm killed by death
Does the rear kx85 caliper bolt right up to the 200x front with same mounting holes? I'm looking to put a 200x front on my 250sx. Also what master cylinder do i use? Thanks
This thread has everything you need to know about caliper swaps for first gen 200X equipment .
http://www.3wheelerworld.com/showthread.php?t=65970
I've used any front master from Honda dirtbike, quads, or other trikes on my trikes and had no issues. I'm running a TRX front master on my ATC and an XR front master on another trike. Used a few CR front master on trikes too.
