Results 1 to 11 of 11
Thread: Need help 86 250r rear disk hub question
    kasuki's Avatar
    kasuki is offline At The Back Of The Pack Arm chair racerFirst time rider
    gasport,NY
    205
    what is this on the rear disk hub looks like a race but its not .it was on the hub its self looks like a bushing for seal to ride on any idea's doesn't show on microfiche?Click image for larger version.
ID:	247501[ATTACH=Click image for larger version.
ID:	247501Click image for larger version.
    The Open Road
    4,736
    This is my theory
    Sometimes when the seal wears grooves too deep, a machinist will turn down the seal area and then make a sleeve to fit over that to bring the part back to it's original outer diameter.
    They are supposed to be pressed or shrunk fit on there with an interference fit so that it won't come off like that one did. A seal surface can also be built up with weld and turned back down to size but then you have to deal with the effects of lots of heat on that hub.
    Mexico
    9,019
    This is my theory
    If that is in fact a sleeve, do you think Loctite would hold it in place if he wants to reuse it?
    The Open Road
    4,736
    Yeah if it's still fairly tight, he can use green loctite to help hold it on. We use green loctite (I think it's 609, iirc) to help hold loose bearing fits.
    From the looks of the pic, the sleeve is rough looking and grooved up but that could just be grease and dirt. If it's nice and smooth inside and out, he could try green loctite on it.
    kasuki's Avatar
    gasport,NY
    205
    Its a friends part he brought to me to make another sleeve at my shop.the part is shot it appears to be a bushing to make up space .but im not a honda guy an was not sure if it was stock
    Carthage NY 250r rules
    2,355
    I saw a thread on a trx 250r site kinda like this but it was a sleeve for the aluminum aftermarket hubs . I would get a different rear disc hub.Or have a new sleeve made and tac weld it on. Or have it pressed on.
    250r rules
    May 2009
    S.E. Michigan
    1,251
    The rear axle bearing carrier seals are 52x62x7. Check if the outer diameter of the sleeve is anywhere close to 52 mm. I agree with the other guys, it looks like a sleeve to clean up the seal surface of the brake hub.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Mexico
    9,019
    It's been bugging me that I couldn't remember the name for those sleeves as I had to put one on a pinion shaft once, but I remembered last night. They called it a "speed sleeve".
    kasuki's Avatar
    gasport,NY
    205
    Im gonna spin up a sleeve today an ill post my results i feel.the same that it was to repair seal surface
    kasuki's Avatar
    gasport,NY
    205
    Ok bike was put back together an used today seemed to work out well .
    House Springs MO
    5,496
    I've got a brake hub stashed away somewhere that looks to have a sleeve in the same spot. I thought it looked different at the time, but didn't pay it much attention.
