Hi all I am doing a total overhaul of a 1983 ytm200k and Yamaha uses Phillips screws to hold the case together and about half of them are oxidized and I have been using a impact driver to try to get them out but not having good luck and my second issue is removing the gear on the crank that turns the timing chain. Looking for any help or special technique that you guys might use.
. You can heat them with a torch *carefully* first, it might help loosen the corroded threads.
