Thread: Freshly rebuilt carb
    Nov 2017
    Southern Minnesota
    16
    Question Freshly rebuilt carb
    Hello again, I have a freshly rebuilt carb from an 85 125m. Could anybody help me out with the initial settings on this so I can attempt to start it?
    Nov 2015
    Davenport iowa
    1,144
    We'll being there is only one setting you need to worry about that being your air/fuel screw I would start at 2 turns out..
    Nov 2017
    Southern Minnesota
    16
    Well I'm actually wondering about the slide needle setting as there is 5 notches that you can put a "c" shaped washer on, and the slide screw that I'm assuming controls how high/low the idle is, and also the air/fuel screw. But I'll try the 2 turns out on the a/f for a start. I have it set at 1 3/8 turns out as of now.
    EDIT** I should say the I have the slide needle 2nd notch up from the bottom 5..
    Nov 2015
    Davenport iowa
    1,144
    Put your needle clip in the middle and start there, if your trike is stock then that's where it should work best.. there is some pretty good explanations on here as to the function of how the carb and each setting works and their affects on the carb, so I won't get into that..Just do a search on carb settings..
    Monroe MI
    5,787
