Thread: Need 83-84 250r Swingarm Bolt Measurement ASAP
    House Springs MO
    5,496
    I need to know the diameter of the smooth part of the pivot bolt. The thread size is 14mm, but apparently the shouldered part of the bolt is slightly larger. Anyone who gets me this measurement will receive $10 off a set of any bushing I make.
    Sent from my SM-G900V using Tapatalk
    Carthage NY 250r rules
    2,355
    Its the same as the 85-86 250r.This is the 85-86 250r
    pivot bolt in the 83 swingarm. Click image for larger version.
    250r rules
    House Springs MO
    5,496
    Thank you. Send me your address and I'll get a set of brake stay bushings to you
    2,355
    Bryan ,The 81-82 250r has the same diameter pivot bolt as the 83-86 250r. Also has the same size needle pivot bearing as the 85-89 250r.
    250r rules
