Results 1 to 15 of 25
Thread: Wheeler pulling hard to the right on pavement?
    fargo north dakota
    16
    I recently found a mint barn find it is a 200s
    The guy put a new left tire on it and a new one
    In front all are same as original. If I drive it on pavement
    It wants to pull hard to the right? I’ve tried diff air pressure.
    Sounds like a dumb
    Question but is driving me nuts trying to figure it out.
    Machine is mint with low hours so doubt it’s
    Bushings. There is a tube in the right tire but figured
    That wouldn’t have much to do with it. Any help
    Would be great sorry for long post.
    Michigan
    1,144
    Make sure the tires have the same air pressure in them.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    AMK's Avatar
    AMK is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2017
    Shelby, OH
    181
    With a new tire on one side and an old one on the other I'd go for the same height or circumference instead of pressure.
    Alan
    1985 350x
    1984 200es Big Red
    1985 200s (little red)
    1986 200x saga
    2) 1985 350x projects
    And a slew of others to hold my attention
    Mar 2008
    Tug Hill
    1,282
    Ya if the tire on the left has more tread its going to pull to the right. If the left tire is still like new id buy another for the right but if its already wore your gonna have to get 2 new tires if you wanna do it right and have no pull.
    Jan 2013
    minnesota
    5,911
    inflate both rear tires until they are both the same circumference and try it. If it still pulls hard to the side something is bent and/or the axles are out of square and it is then not quite as mint as you think it is.
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR AND THE ONLY PERSON ON 3WW WITHOUT AN EDIT BUTTON OR A STAR
    fargo north dakota
    16
    Ok thanks guys. I’ll put new tire on right side appreciate the help.
    Mar 2008
    Tug Hill
    1,282
    im thinking thats gotta be the issue if theres a decent tread difference. when the rear bearings go bad you can usually tell just by trying to wiggle the rear end back n forth.
    Question does it still pull to the right if your in a wheelie?
    Monroe MI
    5,787
    If, after getting them the same height, it still pulls to the right, I would swap the rear tires and then see if it pulls to the left (or not).
    Mar 2008
    Tug Hill
    1,282
    you cant just try to use different psi to even them out thats guess work at best better off buying another new tire so even if that isn't the issue at least you've ruled it out. You'll be there all day fartin' around trying to get the right tire pressure and if they are rounded knobbies then you'll have less tire mass touching on one side and so on.
    May 2016
    OH Canada
    1,102
    Are the rear tires the same ply?
    Why is there a tube in the right tire? Figured the guy would have replaced all 3 tires...
    '83 200X
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by MonroeMike View Post
    yup, this also but only after you inflate them to the same circumference.
    Monroe MI
    5,787
    That's what I meant by height, if they are both aired up to, let's say 22" tall, from the bottom of the tire to the top of the tire, wouldn't they be the same circumference?
    Oct 2017
    Hutto, TX
    75
    One of my trikes, when I first got it, did the same thing. I thought it was the rear bearings, but it turned out to be the front one. I didn’t feel any wiggle in it, but I was determined to figure it out. When I took the front wheel off, only then was I able to see that the bearing was bad.
    Mar 2008
    Tug Hill
    1,282
    Like i said trying to get the right height with different psi is guess work and one might end up with less tread in contact which will also change things its just not feasible. you might as well just buy a new tire even if thats not the main cause at least its taken care of. And like spacerust explained it could be the front thats why i said try doing a wheelie if it rides true in a wheelie its a front end problem either spindle bearings or axle bearings.
    But i guarantee if the tire isn't the main problem its a contributing issue and they aren't that expensive so it would be the wise choice to just replace it and be done with that aspect of the problem.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by lndy650 View Post
    Like i said trying to get the right height with different psi is guess work...
    Well, I for one said to measure the circumference not height/diameter, and there is nearly zero guess measuring it the way I suggested unless someone is unable to read the numbers on the measuring tape correctly.
    ...and one might end up with less tread in contact which will also change things its just not feasible.
    Wrong, it is definitely feasible.
    And like spacerust explained it could be the front...
    ummm...my post also suggests it could be the front.
    ...thats why i said try doing a wheelie if it rides true in a wheelie its a front end problem
    This is what is not feasible and it may NOT determine anything of value, because in addition to a potential difference in tire circumference of the tires if they are not measured first, this "test" also relies upon a perfectly centered weight distribution from side to side.
