Results 1 to 7 of 7
Thread: Tri Z question
    Jul 2017
    5
    Tri Z question
    Hey, joined a while back and now I have a few questions cuz I want to be riding before the snow melts..
    Long long ago I had an '85 225DX which I traded for a paint job on my first car summer of '86..
    Okay, enough ancient history. I bought a couple of Tri Zs plus a bent frame, engine/trans, swingarm, and a box of stuff.
    The runner is an 86 but low compression and I do not know the bore size and if it can take another bore.
    The other stuff is all '85. The complete '85 does not shift, suspect a bent shift fork, but its tight, motor has great compression.
    I haven't screwed with the bare engine/trans but it seems like compression is decent.
    Question is, and I have very little experience with 2 stroke bikes, can I use the piston and jug off one of the other engines and just bolt and go( assuming fresh gaskets)? Any issue with throwing a piston on a different connecting rod without having it checked- again assuming its not sloppy loose or tight on the wrist pin?
    Thanks
    dstryr, since 1986.
    1- 1986 Tri-Z 250
    1- 1985 Tri-Z 250
    1- 1983 225DX
    1- 1969 GTO The Judge
    1- 1969 Six Pack Super Bee
    1- 2019 Arctic Cat ZR8000
    1- 2016 Polaris Switchback Pro S 600
    N.E. Ohio
    2,002
    The jugs are identical and are interchangeable if that's what your asking. Motor mounts are the same for both years as well. Research interchangable part for Tri-Z in the forums good read.
    Jul 2017
    5
    Any reason to Not just swap a good piston and jug onto the running machine rather than do a top end rebuild? I can't verify the original jug on the 86 has room for another bore. But, the jug and piston on the 85 with shifter problems has great compression and starts in one or two kicks every time. Wanted to know if swapping the piston and jug from that to the 86 to get running would be unwise for any reason.
    dstryr, since 1986.
    1- 1986 Tri-Z 250
    1- 1985 Tri-Z 250
    1- 1983 225DX
    Tri Z question
    You should have no issues at all according to what that guy is telling you.
    House Springs MO
    5,496
    Quote Originally Posted by dstryr View Post
    Tri-z 250 was confirming what you are asking. The 85 cylinder will swap on the 86 no problem.
    Sent from my SM-G900V using Tapatalk
    Jul 2017
    5
    Thanks guys, didn't mean to split hairs, I understand the parts interchange, and it doesn't sound like there's concern on just swapping old parts with respect to clearances on the wrist pin. I'm going to do it, if the pin is sloppy or tight then it needs to come apart anyway.
    dstryr, since 1986.
    1- 1986 Tri-Z 250
    1- 1985 Tri-Z 250
    1- 1983 225DX
    Mexico
    9,018
    Like everyone said, no problem, but make sure you pressure test for leaks before you run the engine you worked on.
    It sucks to get old
